Ring Battery Video Doorbell - Satin Nickel
Quicklinx: HVW8WS00 Mfr#: B0BZWQP9Z1
Type: Smart doorbell
Compatible With: Alexa
Colours:
Hurry, only 2 left in stock!
£83.33 ex VAT
£99.99 inc VAT
Express delivery Order within the next 17 hours for delivery on Monday
Wireless Video Doorbell with Head-To-Toe View.
  • Versatile power options
    The Ring Battery Video Doorbell is equipped with both hardwired and battery-powered options, enabling flexible installation that fits various home setups.
  • Superior video quality
    With a maximum digital video resolution of 1440 x 1440, this doorbell provides clear images, allowing for easy identification of visitors.
  • Enhanced visibility day and night
    Thanks to Color Night Vision technology, homeowners can enjoy a clear view of their entrance even in low light conditions, maximizing security.
  • Customizable detection settings
    Privacy and motion zones can be adjusted according to user preference, ensuring that only relevant activity is monitored.
  • Broad coverage with wide field of view
    The 150° horizontal and vertical field of view allows the doorbell to capture a wide area, providing coverage of the front entrance.
Ring Battery Video Doorbell - 2024 Edition - smart doorbell - 30-day free trial of Ring Home, DIY video, easy to install, head-to-toe view, easy to install - 802.11b/g/n - satin nickel
Smart doorbell - with camera
Functions
Motion detection
Power Source
Battery, hardwired
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Camera
Max Resolution 1440 x 1440 Day&Night
Satin nickel
1-year warranty
6.19 cm x 2.3 cm x 12.5 cm
Functions
Motion detection
Power Source
Battery, hardwired
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Two-way audio support
Camera
Day & Night Functionality
Max Digital Video Resolution
1440 x 1440
Privacy zones, Live View Control, Colour Night Vision, customisable motion zones, 150° field of view (horizontal), 150° field of view (vertical), noise cancellation
Software
Ring Home (30 days trial)
USB-C cable, mounting bracket, mounting kit, security sticker
Satin nickel
AC 8 - 24 V
Warranty
1-year warranty
6.19 cm
2.3 cm
12.5 cm
-20 °C
50 °C
Brand: Ring
