Add Range Extenders throughout your home to extend the signal from your Alarm Base Station to all Alarm components, so you can make sure your security coverage stays strong and clear.
*Requires the Ring Alarm Base Station.
Seamless connectivity
The Ring Alarm Range Extender ensures your Ring devices maintain a constant and reliable wireless connection throughout your home, thanks to its Z-Wave wireless protocol technology. This extender module is designed to eliminate dead zones, providing uninterrupted protection and surveillance. -
Robust environmental adaptability
Built to operate in a wide range of temperatures, from 0°C to 40°C, the Alarm Range Extender is equipped to maintain its functionality in various environmental conditions. This adaptability ensures your home security system remains operational, regardless of the weather outside.
- Ring Alarm Range Extender - extender module - Z-Wave - white
- Product Type
- Extender module
- Power Source
- Power adapter, battery
- Connectivity
- Wireless - Z-Wave
- White
- 1-year warranty
- 4.6 cm x 2.8 cm x 8 cm
- Product Type
- Extender module
- Power Source
- Connectivity Technology
- Wireless - Z-Wave
- Max Range Indoors
- 76.2 m
- 24 hours backup battery
- White
- Warranty
- 1-year warranty
- 4.6 cm
- 2.8 cm
- 8 cm
- 0 °C
- 40 °C
