Ring Alarm Motion Detector (2nd Gen)
Quicklinx: GBQ0WS00 Mfr#: B08J6C5JJN
Type: Motion sensor
Compatible With: Alexa
£21.18 ex VAT
£25.41 inc VAT
The Ring Alarm Motion Detector expands your Ring Alarm Kit and adds an extra layer of security to your home. When your Ring Alarm system is armed, the Motion Detector sends instant alerts to your phone and tablet whenever motion is detected at home. The Motion Detector is a simple addition to your Ring Alarm Kit that installs in minutes.
  • Easy installation
    Designed for effortless setup, the Ring Alarm Motion Detector can be mounted on any corner or wall, providing flexibility in securing your home.
  • Wireless convenience
    With Z-Wave wireless protocol, this motion sensor ensures a reliable connection to your home security system without the need for cumbersome wiring.
  • Adaptable performance
    Capable of operating in a wide range of temperatures from 0°C to 49°C, the Ring Alarm Motion Detector is built to perform reliably in various environmental conditions.
Ring Alarm Motion Detector - 2nd Generation - motion sensor - Z-Wave - white
Motion sensor
Power Source
Wireless - Z-Wave
White
1-year warranty
6.6 cm x 3.89 cm x 6.6 cm
Motion sensor
Power Source
Wireless - Z-Wave
Max Range Indoors
76.2 m
Wall mountable, false alarm immunity, corner mountable
Motion Sensor
Detection Mode
Passive infrared (PIR)
AA type
Battery Included
Required Qty
2
Battery Lifetime
3 years
White
Warranty
1-year warranty
6.6 cm
3.89 cm
6.6 cm
49 °C
Type: Motion sensor
Brand: Ring
