Add Alarm Keypads to your second floor, garage and other areas to easily arm and disarm your Alarm system while indoors.
*Requires the Ring Alarm Base Station.
Effortless control
The Ring Alarm Keypad offers seamless integration into your home security system, allowing for easy arming and disarming. Its wireless connectivity ensures that you can place it anywhere in your home for convenient access. -
Adaptable to your environment
Designed to operate between 0°C and 40°C, the Ring Alarm Keypad is built to withstand a variety of environmental conditions, ensuring reliable performance no matter where you live. -
Versatile power options
With the flexibility to be powered by either a battery or a power adapter, the Ring Alarm Keypad ensures your home security system remains operational, even in the event of a power outage.
- Ring Alarm Keypad - control panel - Z-Wave - white
- Product Type
- Control panel
- Environment
- Indoor
- Functions
- Alarm control
- Power Source
- Battery, power adapter
- Connectivity
- Wireless - Z-Wave
- Input Type
- Keypad
- White
- 1-year warranty
- 14.9 cm x 2.3 cm x 10 cm
- Product Type
- Control panel
- Environment
- Indoor
- Functions
- Alarm control
- Power Source
- Connectivity Technology
- Wireless - Z-Wave
- Max Range Indoors
- 76.2 m
- Wall mountable, surface mountable, arm/disarm function
Control Unit
- Input Type
- Keypad
- Battery Lifetime
- 10 months
- Included Accessories
- Wall mount bracket
- White
- Warranty
- 1-year warranty
- 14.9 cm
- 2.3 cm
- 10 cm
- 0 °C
- 40 °C
