Ring Alarm Contact Sernor (2nd Gen) - 2 Pack
Quicklinx: HDNNWS00 Mfr#: B08L5BZFJ7
Type: Door and window sensor
Compatible With: Alexa
2 In Stock
£25.69 ex VAT
£30.82 inc VAT
Standard delivery Delivered within 3-5 working days
Get real-time notifications the moment doors or windows open in your home. Now with a more compact design and slim removable magnets for easy installation, even when space is limited.
  • Easy, tool-free installation.
  • Mounts to doors and window frames.
  • 4 x CR2032 Lithium Coin Cell 3V
  • Alexa can notify you when your Ring Alarm Contact Sensors and Motion Detectors are running low on batteries.
Requires Ring Alarm Base Station. Compatible with 1st and 2nd generation Ring Alarm devices and accessories.
Manufacturer Warranty - 1 Year
  • Effortless installation
    Designed for easy setup, the Alarm Contact Sensor (2nd Generation) can be quickly installed on any door or window to enhance your home security. Its compact form factor ensures it blends seamlessly with your home decor.
  • Smart connectivity
    With Z-Wave wireless protocol, this sensor ensures reliable connectivity and extends up to 76 m in open space, making it suitable for all types of homes. Compatibility with the Ring Alarm Base Station and Alexa enables a smarter, more integrated home security system.
  • Durable battery life
    Powered by a CR2032 lithium battery, the sensor offers a long-lasting performance, ensuring your doors and windows are monitored without frequent battery replacements. The 3 V battery is efficient and maintains the sensor's readiness.
  • Real-time alerts
    Stay informed with real-time notifications sent directly to your phone whenever a door or window is opened. This feature allows you to monitor your home's security from anywhere, providing peace of mind.
  • Adaptable to your environment
    The sensor operates within a wide range of temperatures, from 0°C to 49°C, making it versatile for any indoor environment. Its robust design ensures reliable operation in different climatic conditions.
Ring Alarm Contact Sensor (2nd Generation) - door and window sensor - Z-Wave (pack of 2)
Packaged Quantity
2 (specifications are for single item)
Environment
Indoor
Power Source
Intelligent Assistant
Alexa
Wireless - Z-Wave
1-year warranty
4 cm x 1.4 cm x 5.3 cm
Packaged Quantity
Environment
Indoor
Power Source
Wireless - Z-Wave
Max Range Open Space
76 m
Real-time notifications
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Alexa
CR2032
Required Qty
2
Lithium
Voltage Provided
3 V
Warranty
1-year warranty
4 cm
1.4 cm
5.3 cm
49 °C
Brand: Ring
