Ring Alarm Contact Sensor (2nd Gen)
Quicklinx: GBPZWS00 Mfr#: B08J6SJBFD
Type: Door and window sensor
Compatible With: Alexa
8 due in 3-4 days
£14.12 ex VAT
£16.94 inc VAT
Expand your Ring Alarm system to secure each door and window in your home, and get alerts as soon as they open. Ring Alarm Contact Sensors easily mount to any door or window frame in your home for easy, DIY installation. Connect them to your Ring Alarm Base Station and receive mobile alerts from the Ring app whenever your doors or windows open. You'll always be the first to know when something's ajar.
  • Effortless installation
    The Ring Alarm Contact Sensor offers a straightforward, battery-powered setup that requires no complex wiring, making it an ideal choice for homeowners seeking a hassle-free security solution.
  • Seamless connectivity
    Utilizing Z-Wave wireless protocol, this door and window sensor ensures reliable connectivity, enabling real-time alerts and seamless integration with your home security ecosystem.
Ring Alarm Contact Sensor - 2nd Generation - door and window sensor - Z-Wave - white
Environment
Indoor
Power Source
Wireless - Z-Wave
White
1-year warranty
5.3 cm x 1.4 cm x 4 cm
Environment
Indoor
Power Source
Wireless - Z-Wave
Max Range Open Space
76.2 m
CR2032
Battery Included
Required Qty
2
Battery Lifetime
3 years
White
Warranty
1-year warranty
5.3 cm
1.4 cm
4 cm
49 °C
Brand: Ring
Stock Status: Due in 3-4 days
