Ring Alarm 5 Piece Kit (2nd Gen)
Quicklinx: GBQ4WS00 Mfr#: B08L5TWL9D
Type: Home security system
Compatible With: Alexa
More than 50 In Stock
£183.33 ex VAT
£219.99 inc VAT
Standard delivery Delivered within 3-5 working days
Ring Alarm 5 Piece Kit (2nd Generation) is a great way to get started in whole-home protection for your house or flat. This kit includes a Base Station, Keypad, one Contact Sensor, one Motion Detector, and a Range Extender.
  • New-look Keypad, slimmer Contact Sensor and more discreet Motion Detector
  • Control it all in the Ring app for whole-home security at your fingertips
  • Receive real-time notifications when your system is triggered
  • Choose between three security modes: Home, Away, and Disarmed
  • Alert others in an emergency with new panic buttons
  • Easily expand your whole-home protection with additional Contact Sensors,
  • Motion Detectors and Outdoor Siren
  • Add Assisted Monitoring and Cellular Backup with a Ring Protect Plan
  • Everything you need for tool-free, DIY installation comes in the box
  • Works with compatible Alexa-enabled devices for voice control
  • Compatible with 1st and 2nd generation devices and accessories
  • Enhanced connectivity
    With both wired and wireless connectivity options, including Ethernet, Wi-Fi, and Z-Wave, this home security system offers flexible installation and easy integration into your existing smart home setup.
  • Comprehensive security
    The Alarm Security Kit comes equipped with a base station, extender, keypad, and motion sensor, ensuring your home is monitored from every angle. The 104 dB siren sound level provides a loud alert in case of security breaches, making it an effective deterrent against potential intruders.
  • Reliable power options
    Powered by both a battery and a power adapter, and featuring a 24-hour backup battery, this system ensures your home remains secure even in the event of a power outage.
Ring Alarm Security Kit - 2nd Generation - 5-piece set - home security system - Wi-Fi, Z-Wave - white
Environment
Indoor
Power Source
Battery, power adapter
Package Content
Door and window sensor, motion sensor, keypad, base station, extender
Wireless, wired - Wi-Fi, Z-Wave - Ethernet
Siren Sound Level
104 dB
Input Type
Keypad
White
1-year warranty
Environment
Indoor
Power Source
Package Content
Wireless, wired - Ethernet, Z-Wave, Wi-Fi
Max Range Open Space
76 m
Siren Sound Level
104 dB
Status notification, 24 hours backup battery, Away Mode, Home Mode, panic button, arm/disarm function
Control Unit
Input Type
Keypad
AA / CR2032
Battery Included
2 power adapters
White
AC 100-240 V
Warranty
1-year warranty
Dimensions & Weight Details
Base station: 17 cm x 17 cm x 3.7 cm , Keypad: 10.5 cm x 1.9 cm x 11.2 cm , Door and window sensor: 4 cm x 1.4 cm x 5.3 cm , Motion sensor: 6.6 cm x 3.6 cm x 6.6 cm , Extender: 4.7 cm x 3.5 cm x 8.1 cm
Brand: Ring
