Ring Alarm 5 Piece Kit (2nd Generation) is a great way to get started in whole-home protection for your house or flat. This kit includes a Base Station, Keypad, one Contact Sensor, one Motion Detector, and a Range Extender.
- New-look Keypad, slimmer Contact Sensor and more discreet Motion Detector
- Control it all in the Ring app for whole-home security at your fingertips
- Receive real-time notifications when your system is triggered
- Choose between three security modes: Home, Away, and Disarmed
- Alert others in an emergency with new panic buttons
- Easily expand your whole-home protection with additional Contact Sensors,
- Motion Detectors and Outdoor Siren
- Add Assisted Monitoring and Cellular Backup with a Ring Protect Plan
- Everything you need for tool-free, DIY installation comes in the box
- Works with compatible Alexa-enabled devices for voice control
- Compatible with 1st and 2nd generation devices and accessories
Enhanced connectivity
With both wired and wireless connectivity options, including Ethernet, Wi-Fi, and Z-Wave, this home security system offers flexible installation and easy integration into your existing smart home setup. -
Comprehensive security
The Alarm Security Kit comes equipped with a base station, extender, keypad, and motion sensor, ensuring your home is monitored from every angle. The 104 dB siren sound level provides a loud alert in case of security breaches, making it an effective deterrent against potential intruders. -
Reliable power options
Powered by both a battery and a power adapter, and featuring a 24-hour backup battery, this system ensures your home remains secure even in the event of a power outage.
- Ring Alarm Security Kit - 2nd Generation - 5-piece set - home security system - Wi-Fi, Z-Wave - white
- Product Type
- Home security system
- Environment
- Indoor
- Power Source
- Battery, power adapter
- Package Content
- Door and window sensor, motion sensor, keypad, base station, extender
- Connectivity
- Wireless, wired - Wi-Fi, Z-Wave - Ethernet
- Siren Sound Level
- 104 dB
- Input Type
- Keypad
- White
- 1-year warranty
- Product Type
- Environment
- Indoor
- Power Source
- Package Content
- Connectivity Technology
- Wireless, wired - Ethernet, Z-Wave, Wi-Fi
- Max Range Open Space
- 76 m
- Siren Sound Level
- 104 dB
- Status notification, 24 hours backup battery, Away Mode, Home Mode, panic button, arm/disarm function
Control Unit
- Input Type
- Keypad
- Form Factor
- AA / CR2032
- Battery Included
- Included Accessories
- 2 power adapters
- White
- Voltage Required
- AC 100-240 V
- Warranty
- 1-year warranty
- Dimensions & Weight Details
- Base station: 17 cm x 17 cm x 3.7 cm , Keypad: 10.5 cm x 1.9 cm x 11.2 cm , Door and window sensor: 4 cm x 1.4 cm x 5.3 cm , Motion sensor: 6.6 cm x 3.6 cm x 6.6 cm , Extender: 4.7 cm x 3.5 cm x 8.1 cm
- 0 °C
- 40 °C
