Ring Alarm 5-pc Starter Kit
Quicklinx: GBQ5WS00 Mfr#: 4K11D9-0EU0
When armed, the Ring Alarm Security Kit sends notifications to your phone and tablet whenever doors or windows open and when motion is detected at home. It's fully customizable and expands to fit any house or apartment. And the free Ring App puts your entire home security system at your fingertips. It also has a Panic Mode feature, which allows you to dispatch emergency services right from your Keypad.
  • Enhanced connectivity
    With both wired and wireless connectivity options, including Ethernet, Wi-Fi, and Z-Wave, this home security system offers flexible installation and easy integration into your existing smart home setup.
  • Comprehensive security
    The Alarm Security Kit comes equipped with a base station, extender, keypad, and motion sensor, ensuring your home is monitored from every angle. The 104 dB siren sound level provides a loud alert in case of security breaches, making it an effective deterrent against potential intruders.
  • Reliable power options
    Powered by both a battery and a power adapter, and featuring a 24-hour backup battery, this system ensures your home remains secure even in the event of a power outage.
Ring Alarm Security Kit - 1st Generation - 5-piece set - home security system - ZigBee, Wi-Fi, Z-Wave - white
Home security system
Power Source
Battery, power adapter
Intelligent Assistant
Alexa
Package Content
Door and window sensor, motion sensor, keypad, base station, extender
Wireless, wired - ZigBee, Wi-Fi, Z-Wave - Ethernet
Siren Sound Level
104 dB
Input Type
Keypad
White
1-year warranty
Power Source
Package Content
Wireless, wired - Ethernet, Z-Wave, ZigBee, Wi-Fi
Max Range Indoors
76.2 m
Siren Sound Level
104 dB
Android, Apple iOS
24 hours backup battery, panic function Bluetooth management
Control Unit
Input Type
Keypad
Built-in Devices
Internet of Things (IoT)
Alexa
Battery Included
White
Nominal Voltage
AC 120/230 V
Warranty
1-year warranty
Dimensions & Weight Details
Base station: 16.9 cm x 3.61 cm x 16.9 cm , Keypad: 10.5 cm x 1.91 cm x 11.2 cm , Door and window sensor: 3.96 cm x 1.4 cm x 5.31 cm , Motion sensor: 6.6 cm x 3.89 cm x 6.6 cm , Extender: 4.72 cm x 4.22 cm x 8.1 cm
