- BLE remote control suitable for the RICOH THETA series. A BLE remote controller that can be easily connected and can easily release the shutter remotely without connecting to a smartphone wirelessly.
- Bluetooth Low Energy power saving design. Battery life is 100 days (when the power is turned on for 8 hours a day and the shooting signal is transmitted 50 times).
- Thin size with a thickness of 12 mm.
- Pairing state with THETA can be maintained for 8 hours in a row, there is no need to reconnect.
- Reliable weather resistant construction
- [Compatible models] RICOH THETA SC2, RICOH THETA Z1, RICOH THETA V (as of September 2020)
- Made of aluminium, which is lightweight yet has excellent stability. High-quality emboss processing.
- An attachment for the THETA selfie stick (TM-2 / TM-3) is included.
- Ricoh TR-1 camcorder remote control
- Camcorder remote control
- 1.2 cm
- Supported Devices
- Camcorder
- Wireless Technology
- Bluetooth
- Battery
- CR2032
- Designed For
- Ricoh THETA SC2, THETA V, THETA Z1
- 1.2 cm
- Bluetooth
- Supported Devices
- Camcorder
- Splashproof
- Included Accessories
- Attachment for selfie stick
- Battery
- CR2032
- Designed For
