Ricoh Theta SC2 360 Camera - Grey
Quicklinx: H1LDWS00 Mfr#: 910812
Type: Compact
Resolution: 12Megapixel, 12Megapixel
Optical Zoom: 0
Colour: Grey
£263.73 ex VAT
£316.47 inc VAT
Easy to use, the THETA SC2 for Business allows any beginners to capture high-quality 360-degree images.
Specially created for business activities, THETA SC2 for Business is the tool which will help you to immerse your collaborators and customers into your projects.
Aside from the unlimited possibility it gives to viewers and content creators; it encourages engagement and, through this, has over 3 times the conversion rate of traditional video content and a 30% higher repeated view rate. The RICOH THETA SC2 for Business snaps photos at approximately 14 megapixels with smooth, immersive 360°spherical video at 30 fps (frames per second) in 4K (3840 × 1920 pixels).
Ricoh THETA SC2 - for Business - camcorder - internal flash memory
Camcorder - 4K
Synchronised Camera Array
Spherical panorama
Media Type
Internal flash memory
Internal Storage
14 GB flash
Wireless Interface
Wireless LAN, Bluetooth
Sensor Resolution
2 x 12.0 MP
Max Video Resolution
3840 x 1920
Lens System
2 x fisheye lens f/2.0
Focus Adjustment
Focus free
Min Focus Distance
10 cm
Image Stabiliser
Electronic
Supported Battery
Li-ion rechargeable battery (included)
Grey
4.52 cm x 2.29 cm x 13.06 cm
104 g
3-year warranty
Camcorder - 4K
Enclosure Colour
Grey
Camcorder Type
Pocket
Sensor Resolution
2 x
Camcorder Sensor Resolution
12.0 MP
Sensor Qty
1 CMOS
360° Camera
Camcorder Media Type
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
30 fps
ISO (Max)
6400
Image Stabiliser
Electronic
Face Detection
Print Standard
Exif Print support
Face Detection
Face Recognition
Digital Video Format
H.264
Image Recording Format
JPEG
3840 x 1920
Audio Signal Format
AAC LC
Connectivity Features
Remote control via mobile devices, remote live view, Wireless Image Transfer
Exposure & White Balance
Light Sensitivity
ISO 64-6400
Exposure Modes
Programme, automatic, manual, shutter-priority, ISO priority
White Balance
Automatic, presets
White Balance Presets
Incandescent, cloudy, outdoor, shade, Underwater, fluorescent light (warm white), fluorescent light (daylight colour), fluorescent light (natural white), fluorescent light (white), 2500K - 10000K
Max Shutter Speed
1/25000 sec
Min Shutter Speed
60 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
2 x fisheye lens f/2.0 - fisheye
Focus Adjustment
Focus free
Min Focus Distance
10 cm
Lens Construction
6 groups / 7 elements
Additional Features
Self-Timer Delay
10 sec, 2sec, 30 sec
Additional Features
Interval shooting mode
360° Camera
Panorama Type
Spherical
Optical Sensor Qty
2
Connector Type
USB 2.0 (5 pin Micro-USB Type B)
Soft case, USB cable, lens cap
Battery Type
Lithium Ion - integrated
Details
Battery Life Details
Photo shooting - 260 shots , Video recording - 60 minutes
Memory / Storage
Internal Storage
14 GB flash
Image Storage
5376 x 2688
Video Capture
H.264 - 3840 x 1920 p - 29.97 fps , H.264 - 1920 x 960 p - 29.97 fps
Limited warranty - 3 years
4.52 cm
2.29 cm
13.06 cm
104 g
0 - 90%
Type: Compact
Optical Zoom: 0
Colour: Grey
Brand: Ricoh
