The RICOH THETA SC2 is an easy-to-use model, perfect for the 360 enthusiast, allowing anyone to capture high-quality spherical images. It snaps photos at approximately 14 megapixels, and smooth, immersive 360°spherical video at 30 frames per second in 4K (3840 x 1920 pixels). Additionally, the RICOH THETA SC2 comes with a variety of shooting modes such as "Face" mode, which recognizes human faces and applies skin smoothing, and "Night View" mode for shooting low-noise footage after the sun goes down. These modes allow the photographer to configure the camera with minimal effort.
- Ricoh THETA SC2 - camcorder - internal flash memory
- Product Type
- Camcorder - 4K
- Synchronised Camera Array
- Spherical panorama
- Media Type
- Internal flash memory
- Internal Storage
- 14 GB flash
- Wireless Interface
- Wi-Fi, Bluetooth
- Sensor Resolution
- 2 x 12.0 MP
- Max Video Resolution
- 3840 x 1920
- Lens System
- 2 x fisheye lens f/2.0
- Focus Adjustment
- Focus free
- Min Focus Distance
- 10 cm
- Image Stabiliser
- Electronic
- Supported Battery
- Li-ion rechargeable battery (included)
- Blue
- 4.52 cm x 2.29 cm x 13.06 cm
- 104 g
- 1-year warranty
- Product Type
- Camcorder - 4K
- Enclosure Colour
- Blue
- Camcorder Type
- Sensor Resolution
- 2 x
- Camcorder Sensor Resolution
- 12.0 MP
- Sensor Qty
- 1 CMOS
- 360° Camera
- Camcorder Media Type
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 30 fps
- ISO (Max)
- 6400
- Image Stabiliser
- Electronic
- Print Standard
- Exif Print support
- Digital Video Format
- H.264
- Image Recording Format
- JPEG
- 3840 x 1920
- Audio Signal Format
- AAC LC
- Interface
- Wireless LAN, Bluetooth
- Connectivity Features
- Remote control via mobile devices, remote live view, Wireless Image Transfer
Exposure & White Balance
- Light Sensitivity
- ISO 64-6400
- Exposure Modes
- Programme, automatic, manual, shutter-priority, ISO priority
- White Balance
- Automatic, presets
- White Balance Presets
- Incandescent, cloudy, outdoor, shade, fluorescent light (warm white), Underwater, 2500K - 10000K, fluorescent light (daylight colour), fluorescent light (natural white), fluorescent light (white)
- Max Shutter Speed
- 1/25000 sec
- Min Shutter Speed
- 60 sec
Lens System
- 2 x fisheye lens f/2.0 - fisheye
- Focus Adjustment
- Focus free
- 10 cm
- Lens Construction
- 6 groups / 7 elements
Additional Features
- Self-Timer Delay
- 10 sec, 2sec, 30 sec
- Additional Features
- Interval shooting mode
360° Camera
- Panorama Type
- Spherical
- Optical Sensor Qty
- 2
- Connector Type
- USB 2.0 (5 pin Micro-USB Type B)
- Included Accessories
- Soft case, USB cable
- Battery Type
- Lithium Ion - integrated
- Details
- Battery Life Details
- Photo shooting - 260 shots , Video recording - 60 minutes
Memory / Storage
- Internal Storage
- 14 GB flash
- Image Storage
- 5376 x 2688
- Video Capture
- H.264 - 3840 x 1920 p - 29.97 fps , H.264 - 1920 x 960 p - 29.97 fps
- Limited warranty - 1 year
- 4.52 cm
- 2.29 cm
- 13.06 cm
- 104 g
- 0 °C
- 40 °C
- 0 - 90%
