Ricoh SP100E Printer with toner cartridge
Quicklinx: 8LTBWS00 Mfr#: 406946
The Aficio™ SP100e is an affordable and stylish desktop black and white A4 laser printer. Its simplicity makes it ideal for a personal user who wants to utilise Ricoh's market leading technology.
Features:
  • 13 page per minute A4 mono laser printer
  • Compact & Stylish design
  • Fast first print out at less than 13 seconds
  • 16Mb for swift digital printing
  • Up to 1200 x 600 dpi equivalent resolution
  • 50 sheet standard paper capacity
  • High speed USB 2 connectivity
  • Windows compatible
  • Ricoh reliability with target volume of 300 pages per month
Ricoh is one of the world's leading manufacturers of business printers. You can now reap the benefits of our know-how in high quality, great performance printer models designed for entry level users. Introducing: the new Ricoh Aficio™SP 100 e Series.
Specifications:
Warm-up time: 25 seconds First output speed: 13 seconds Continuous output speed: 13 pages per minute Dimensions (W x D x H): 402 x 368.5 x 119 mm Weight: 6.2 kg Power source: 220 - 240 V, 50/60 Hz Duty cycle: 10,000 prints per month Operating System Compatibility: Windows
Ricoh SP 100e - printer - B/W - laser
Printer Type
Personal printer - laser - B/W
Desktop
6.2 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Max Media Size (Custom)
210 mm x 297 mm
Print Speed
Up to 13 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
USB
80 MHz
RAM Installed (Max)
16 MB (16 MB)
Language Simulation
Windows GDI driver
Media Type
Plain paper, recycled paper, thick paper, thin paper
Total Media Capacity
50 sheets
Media Handling
50-sheet input tray
Monthly Duty Cycle (max)
10000 pages
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008
40.2 cm x 36.85 cm x 11.9 cm
Printer Type
Personal printer - laser - monochrome
Desktop
Printer
Print Speed
Wired
USB
1200 x 600 dpi
First Print Out Time B/W
13 sec
Language Simulation
Windows GDI driver
Media Handling
50-sheet input tray
80 MHz
RAM
RAM Installed (Max)
16 MB / 16 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
210 mm x 297 mm
Media Sizes
A4 (210 x 297 mm)
Media Weight
60 g/m² - 105 g/m²
50 sheets
Output Trays Capacity
10 sheets
Duty Cycle
10000 pages
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x maintenance cartridge (black) - up to 500 pages
ISO 9001, ISO 14001
Power supply - internal
Frequency Required
50/60 Hz
250 Watt
Power Consumption Stand by / Sleep
5 Watt
Software Included
Drivers & Utilities
40.2 cm
36.85 cm
11.9 cm
6.2 kg
