The SP 213w is an A4 black-and- white printer that will fit perfectly on your desktop. With its small footprint it won't take up valuable space. It's easy to use because all operations can be managed from the front of the device. Offering standard Wi-Fi, manual double-sided printing, an embedded paper tray and an all-in-one print cartridge, the SP 213w is ideal for small and home offices looking for a productive print solution.
- Ricoh SP 213w - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 7.2 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 22 ppm - max speed
- Max Resolution (B&W)
- 1200 x 600 dpi
- Interface
- USB 2.0, Wi-Fi(n)
- RAM Installed (Max)
- 128 MB
- Language Simulation
- PCL 6
- Media Type
- Plain paper, recycled paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 20000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1
- Microsoft Certification
- Compatible with Windows 7
- 40.2 cm x 36 cm x 16.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- 1200 x 600 dpi
- First Print Out Time B/W
- 10 sec
- PCL 6
- Fonts Included
- 80 x PCL
- Media Handling
RAM
- 128 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 105 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets weight: 60 g/m² - 105 g/m² , 1 x automatic - 1 sheet weight: 60 g/m² - 105 g/m²
- Output Trays Capacity
- 50 sheets
Duty Cycle
- 20000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge - up to 700 pages ISO/IEC 19752
- Power Device
- Power supply
- Frequency Required
- 50/60 Hz
- 400 Watt
- Power Consumption Stand by
- 65 Watt
- Power Consumption Sleep
- 5 Watt
- OS Required
- 40.2 cm
- 36 cm
- 16.5 cm
- 7.2 kg
