The SP 211SF offers everything a small/home office is looking for. Productivity is enhanced with a 22 ppm print speed, color scanning, G3 faxing, manual double-sided printing and high speed USB 2.0. This versatile MFP is easy to use via the user-friendly 4-line LCD panel. All operations can be conveniently managed from the front of the device. The reliable SP 211SF is rounded off by a small footprint, low energy consumption and a cost-efficient all-in-one print cartridge.
- Ricoh SP 211SF - multifunction printer - B/W
- Multifunction printer
- Fax Type
- G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 pages
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 22 ppm
- Max Printing Resolution
- Up to 1200 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- Media Type
- Plain paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 230 V (50/60Hz)
- 40.2 cm x 36 cm x 29.3 cm
- 11.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 20000 pages
- Interface
- USB 2.0
- Standard Memory
- 8 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 22 ppm
- Printer Drivers / Emulations
- Windows GDI driver
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Compatibility
- G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 150 sheets
- 1 sheet
- 50 sheets
- Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet weight: 60 g/m² - 105 g/m² , Output tray - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF weight: 52 g/m² - 105 g/m²
- Speed Details
- Printing: up to 22 ppm
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2
- Voltage Required
- 400 Watt
- Power Consumption Standby
- 65 Watt
- Power Consumption Sleep
- 5 Watt
- Warm-Up Time
- 25 sec
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages
- ISO 9001, ISO 14001, ISO 27001
- ENERGY STAR Certified
- 40.2 cm
- 36 cm
- 29.3 cm
- 11.1 kg
