The RICOH SG 7100DN delivers compelling, eye-catching color on larger sizes up to 11" x 17" while using less power, less space and less of your budget. RICOH innovative, proprietary GELJET viscous ink dries quickly for outstanding, long-lasting color on a wide range of media, from envelopes to banners. This impressive printer combines the affordable convenience of inkjet technology with the speed, reliability and advanced capabilities of a color laser printer.
See the difference quality ink can make. Ricoh's exclusive, GELJET pigment-based ink produces crisp text and concise lines for impressive color with up to 3600 x 1200 dpi resolution. Because the ink dries faster than most competitive options, you can produce two-sided documents, including postcards and handouts, with less bleed through. Plus, it's water-resistant, so envelopes, tickets and other documents can withstand harsher conditions and handling without fading or smearing. Registration alignment is seamless every time with electrostatic technology that keeps paper firmly in place. Use its enhanced Economy Color Mode for color output at a cost-per-page comparable to black-and-white printing while preserving textual density for crisp, clear, legible output every time.
The Ricoh SG 7100DN is packed with value-added features to improve workflow and productivity. It offers fast first print speeds and delivers outstanding color at up to 29 pages-per-minute. Standard duplex printing uses less paper, helping to reduce operating costs. The built-in 250-Sheet Paper Tray accepts media up to 11" x 17" and up to 90 lb. Index for impressive flexibility compared to most inkjet printers. Multiple media options include a 100-Sheet Multi-Bypass Tray for postcards, direct mail and more. Plus, the Bypass Tray accepts larger stocks up to 51" long and 140 lb. Index for banners and signs. Add an optional 250- Sheet Paper Feed Unit to increase media capacity to 600 sheets. Use standard or optional trays to print envelopes without compromising speed or efficiency.
The GELJET advantage
GELJET printers use fast-drying viscous, pigment-based Liquid Gel that does not permeate paper and dries fast. It delivers high quality color at low cost on plain paper. And, because Liquid Gel dries instantly, it also enables high-speed duplex printing. -
Unique ECOnomy color
In ECOnomy color mode, GELJET can distinguish between text and images - text is printed solid black, while image thickness is reduced by half. So you get quality color documents at virtually the cost of black and white. -
User-friendly design
With the control panel and operations accessible from the front, these versatile printers fit virtually anywhere. There is also easy USB and network connectivity, and simple envelope setup straight from the printer driver window. -
Improve productivity
Get your first color print in 8 seconds. Enjoy fast output at up to 29 ppm and uninterrupted print runs using high capacity paper tray options. Thanks to the wide paper support and multi bypass tray option, you can easily print posters, banners, envelopes and custom papers. -
Avoid outsourcing
GELJET can handle a wide range of paper sizes and weights. You can even print double-sided with the Aficio SG 7100DN's paper-saving duplex unit. This gives you the flexibility to create a variety of professional-looking color documents in-house. -
Think bigger
Need a solution for your large format color printing needs? The surprisingly compact and extremely versatile Aficio SG 7100DN lets you print anything from Excel spreadsheets to architectural drawings from A4 up to big, easy-to-read A3 size. -
Enjoy green cost-efficiency
GELJET energy-saving features reflect Ricoh's commitment to the environment. Their power consumption is one of the lowest in their class, helping to reduce CO2 emissions and lower your TCO. GELJET also comply with the latest ENERGY STAR standards.
- Ricoh SG 7100DN - printer - colour
- Printer Type
- Workgroup printer - colour
- Ink Palette Supported (Colours)
- 4-ink
- Media Size Class
- A3
- Automatic Duplexing
- Networking
- Print server
- Power
- AC 230V
- Printer Type
Printer
- 4-ink
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
Media Handling
- Media Size Class
- A3
- Networking
- Print server
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
Environmental Standards
- ENERGY STAR
