Ricoh Optio WG-5 GPS Camera Orange 16MP 4xZoom 3.0LCD FHD Wtprf 14
Quicklinx: BD02WS00 Mfr#: 04663
This digital camera is equipped with a high-performance lens with a maximum aperture 2.0. It has superior brightness with the folded optic zoom lens and is equipped with a high-performance 4.0x optical zoom lens of maximum aperture 2.0. Since the lens is bright, the sensitivity is suppressed even when shooting with the same shutter speed and allows recording in high image quality in dark scenes.
  • High-performance lens
    The camera has superior brightness with the folded optic zoom lens and is equipped with a high-performance 4.0x optical zoom lens of maximum aperture 2.0. Since the lens is bright, the sensitivity is suppressed even when shooting with the same shutter speed and allows recording in high image quality in dark scenes.
  • High sensitivity backside illumination CMOS image sensor
    It's equipped with a backside illuminated CMOS image sensor with excellent light receiving efficiency and offers images with low noise and superior resolution with high definition.
  • Equipped with an electromagnetic compass
    You can display the electromagnetic compass on the LCD monitor and check the latitude, longitude, and atmospheric pressure of the current location. It's also equipped with a GPS function that records the location information on the shooting data.
Ricoh WG-5 GPS - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Sensors
Digital compass, barometer, pressure sensor, digital level metre
Sensor Resolution
16.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 4x zoom - 4.5 - 18 mm - f/2.0-4.9
Focus Adjustment
Automatic, manual
Min Focus Distance
40 cm
Digital Zoom
7.2x
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
Pentax D-Li92 Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Orange
12.5 cm x 3.2 cm x 6.45 cm
216 g
Built-in Light
LED lights
Enclosure Colour
Orange
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
16,790,000 pixels
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
4x
Digital Zoom
7.2x
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
HDR Mode
Auto HDR mode
Navigation
GPS receiver
Sensors
Print Standard
DPOF support, Exif Print support, PRINT Image Matching
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Subject-tracking AF
Face Detection
Blink Detection technology, Face Detection AF/AE, Pet Detection, Smile Capture, Self Portrait Auto Shutter
Digital Video Format
H.264, AVC
Image Recording Format
JPEG
1920 x 1080
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 125-6400
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic, shutter-priority
Shooting Programs
Landscape, portrait mode, macro, text, surf & snow, PET, Blue Sky, food, fireworks, flower, night scene, Underwater, sports mode, sunset, candle, night scene with portrait, kids, report, digital microscope, underwater movie, handheld night shot, interval composite mode, Dynamic Range (HDR), digital IS, green, portrait & sunset, portrait & backlight, portrait & blue sky, group photo
Special Effects
Soft, Black & White, Sepia, Colour, fisheye, miniature, Retro, Colour Extract, brightness, Toy camera, starburst, High contrast, Color Emphasis, Collage
White Balance
Custom, automatic, presets
White Balance Presets
Tungsten light, daylight, shade, fluorescent light (daylight), fluorescent light (daylight white), fluorescent light (white)
Max Shutter Speed
1/4000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
25 - 100mm
Focus Adjustment
Automatic, manual
Min Focus Distance
40 cm
Macro Focus Range
1-50cm
Zoom Adjustment
Motorised drive
Lens Construction
7 groups / 9 elements
Aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.2 m - 10.4 m: ISO auto (wide lens) , 0.2 m - 4.2 m: ISO auto (tele lens)
Additional Features
Self-Timer Delay
10 sec, 2sec, 3sec
Additional Features
RGB primary colour filter, date/time stamp, digital image rotation, in-camera red-eye removal, cropping an image, resizing an image, interval shooting mode, in-camera film editing, Dynamic Range Adjustment, Pixel Track SR, HDR image enhancement technology, NR Slow Shutter, high-speed recording, Time-Lapse recording, Interval Movie Record
Display
3" LCD display
Display Format
460,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
Software
Software
Drivers & Utilities, ArcSoft MediaImpression 2.2 LE, ArcSoft MediaImpression 3.6.2 LE
AC power adaptor, USB cable, macro stand, carabiner strap
Protection
Waterproof, crushproof, freezeproof, shockproof, dust-resistant
Underwater Use
Underwater Depth
Up to 14 m
Battery Type
Pentax D-Li92 Lithium Ion
Details
Battery Life Details
Photo shooting - 240 shots , Playback - 3.3 hours , Video recording - 1.1 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Memory Card Included
No
Image Storage
JPEG 4608 x 3456 , JPEG 3456 x 3456 , JPEG 4608 x 2592 , JPEG 3072 x 2304 , JPEG 3072 x 1728 , JPEG 2592 x 1944 , JPEG 2592 x 1464 , JPEG 2048 x 1536 , JPEG 1920 x 1080 , JPEG 1024 x 768 , JPEG 640 x 480
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 1280 x 720 - 30 fps
12.5 cm
3.2 cm
6.45 cm
216 g
-10 °C
