User-friendly, eco-friendly and cost-efficient, the SP 5210DN printer supports the print needs of busy offices on a budget. You enjoy impressive print speeds, automatic duplexing, excellent paper handling and the security features. For larger workgroups, the space-saving designs can expand from desktop models to five-tray floor-standing powerhouses.
- Ricoh SP 5210DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 23 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 50 ppm - B/W
- Max Resolution (B&W)
- 1200 x 600 dpi
- Automatic Duplexing
- Interface
- USB, LAN, USB host
- Processor
- 533 MHz
- RAM Installed (Max)
- 768 MB (768 MB)
- Hard Drive
- 80 GB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF, XPS
- Media Type
- Envelopes, transparencies, labels, plain paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 550-sheet input tray, 100-sheet bypass tray
- Monthly Duty Cycle (max)
- 200000 pages
- Recommended Monthly Volume
- 5000 - 15000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - integrated
- System Requirements
- UNIX, Citrix Presentation Server, Apple MacOS X 10.2 or later, Microsoft Windows Server 2003, Apple MacOS X 10.2 - 10.2.6, Novell NetWare 6.5 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 41.1 cm x 43.5 cm x 40 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 600 dpi
- First Print Out Time B/W
- 7.5 sec
- Fonts Included
- 58 x PCL , 136 x PostScript 3
- Media Handling
- Processor
- 533 MHz
RAM
- 768 MB / 768 MB (max)
Storage
- Hard Drive
- 80 GB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm)
- Media Weight
- 52 g/m² - 220 g/m²
- 650 sheets
- Media Feeders
- 1 x automatic - 550 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 220 g/m² , 1 x automatic - 100 sheets weight: 52 g/m² - 220 g/m²
- Max Media Capacity
- 2850 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 200000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- TCP/IP, IPX/SPX, AppleTalk, Bonjour
- Remote Management Protocol
- SNMP 3
- SSL, IPsec
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages
- Supported Windows 7 Features
- Windows HD Imaging
- cUL, UL 60950-1, CAN/CSA-C22.2 No. 60950-1
- Power Device
- Power supply - internal
- Frequency Required
- 50 - 60 Hz
- 1.4 kW
- Power Consumption Stand by / Sleep
- 5 Watt
- Software Included
- Font Manager 2000, Web Image Monitor
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- 41.1 cm
- 43.5 cm
- 40 cm
- 23 kg
