High quality color documents on demand? You can with the Aficio SG 2100N. These innovative GELJET printers have network connectivity, a small footprint, full front access and feature Ricoh's fast-drying Liquid Gel technology to simplify color printing in shops, businesses and home offices everywhere.
The GELJET advantage
GELJET printers use fast-drying viscous, pigment-based liquid Gel that does not permeate paper and dries fast. It delivers high quality color at low cost on plain paper. And, because Liquid Gel dries instantly, it also enables high speed duplex printing. -
Unique economy color
In economy color mode, GELJETS can distinguish between text and images - text is printed solid black, while image thickness is reduced by half. So you get quality color documents at virtually the cost of black and white. -
User-friendly design
With the control panel and operations accessible from the front, these versatile printers fit virtually anywhere. There is also easy USB and network connectivity, and simple envelope setup straight from the printer driver window. -
Improved productivity
Get your first color print in 6.5 seconds. Enjoy fast output at up to 29 ppm and uninterrupted print runs using high capacity paper tray options. Easily print banners, envelopes and custom papers. -
Reliable, secure and compliant
GELJETS have a simple architecture with a minimal number of highly durable parts. This ensures maximum reliability and long life. It also comply with the energy star and BAM international standards for energy efficiency and environmental friendliness. -
Green cost-efficiency
With a partially recyclable plant-based plastic chassis, toxic free materials and energy-saving features, GELJETS reflect Ricoh's environmental commitment. GELJETS consume 90% less power than a color laser printer, which not only reduces carbon dioxide emissions.
- Ricoh SG 2100N - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 9.5 kg
- Inkjet Technology
- Ricoh GelJet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 29 ppm - B/W , Up to 29 ppm - colour , Up to 12 ppm - B/W (ISO/IEC 24734) , Up to 12 ppm - colour (ISO/IEC 24734)
- Max Resolution (B&W)
- 3600 x 1200 dpi
- Max Resolution (Colour)
- 3600 x 1200 dpi
- Interface
- USB, LAN
- RAM Installed (Max)
- 32 MB (32 MB)
- Language Simulation
- Ricoh RPCS
- Media Type
- Plain paper
- Total Media Capacity
- 250 sheets
- Monthly Duty Cycle (max)
- 10000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008
- Microsoft Certification
- Compatible with Windows 7
- 39.9 cm x 36 cm x 21.25 cm
- Printer Type
Printer
- Inkjet Technology
- Ricoh GelJet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 3600 x 1200 dpi
- 3600 x 1200 dpi
- First Print Out Time B/W
- 5.5 sec
- First Print Out Time Colour
- 6.5 sec
- Ricoh RPCS
RAM
- 32 MB / 32 MB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 10000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- ISO 9001, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 22.8 Watt
- Power Consumption Stand by / Sleep
- 1.06 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 39.9 cm
- 36 cm
- 21.25 cm
- 9.5 kg
