This user-friendly MFP features a small footprint, full front access and wireless connectivity, making them ideal for retail and office environments where space is limited. With speeds up to 29 pages per minute, these compact MFPs offer high performance copy, print, scan and fax functionality.
The SG 3110SFNw feature Ricoh's fast-drying Liquid Gel technology, which delivers high quality color prints that cannot smudge and are water and sunlight resistant. Color prints are delivered quickly in 6.5 seconds and the standard and optional paper trays enable efficient, uninterrupted print runs. Extended networking is another feature, and there is support for the IPV6 Internet protocol and multiple operating systems.
Fast-drying Liquid Gel technology
The SG 3110SFNw feature Ricoh's fast-drying Liquid Gel technology, which delivers high quality color prints that cannot smudge and are water and sunlight resistant. Color prints are delivered quickly in 6.5 seconds and the standard and optional paper trays enable efficient, uninterrupted print runs. Extended networking is another feature, and there is support for the IPV6 Internet protocol and multiple operating systems. -
Ongoing commitment to the environment
As with all Ricoh products, the SG 3110SFNw reflects Ricoh's ongoing commitment to the environment. It has several environmentally responsible features such as low power consumption, a partially recyclable plant-based plastic chassis and toxic free materials. Further savings come from Ricoh's enhanced technology that reduces gel consumption and enables color printing at a similar cost to black and white using economy color mode. The SG 3110SFNw is also Energy Star compliant.
- Ricoh SG 3110SFNw - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Ricoh GelJet - 4-ink
- Max Copying Speed
- Up to 29 ppm (mono) / up to 29 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 3600 x 1200 dpi (mono) / up to 3600 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Media Size
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi
- Power
- AC 230 V (50/60Hz)
- 39.9 cm x 43.65 cm x 32.95 cm
- 15.3 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified, Blue Angel
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour
- Interface
- Standard Memory
- 256 MB 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Preset Enlargements
- 141%, 200%, 100%
- Preset Reductions
- 50%, 71%, 93%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- Ricoh GelJet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PCL 5c, Ricoh RPCS
- First Print Out Time B/W
- 5.5 sec
- First Print Out Time Colour
- 7 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 250 sheets
- 850 sheets
- 100 sheets
- Speed Details
- Copying: up to 29 ppm - B/W , Copying: up to 29 ppm - colour , Printing: up to 29 ppm - B/W , Printing: up to 29 ppm - colour
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.5 or later
- Software Included
- Drivers & Utilities
- Voltage Required
- 54 Watt
- Power Consumption Standby
- 4.2 Watt
- Warm-Up Time
- 35 sec
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Blue Angel Compliant
- 39.9 cm
- 43.65 cm
- 32.95 cm
- 15.3 kg
