Razer Wolverine V3 Tournament Ed. - Black
Quicklinx: HTJGWS00 Mfr#: RZ06-05210100-R3M1
Wired / Wireless: Wired
Compatibility: Microsoft Xbox Series S, PC, Microsoft Xbox Series X
£82.50 ex VAT
£99.00 inc VAT
Get the edge you need to dominate the competition with the Razer Wolverine V3 Tournament Edition— our most advanced wired esports controller. Officially licensed by Xbox, perform like the pros on Xbox and PC with speed, control, and precision that sets you up for true gaming glory.
4 Mouse Click Back Paddles & 2 Claw Grip Bumpers
  • 6 Remappable Buttons to Outplay Them All
Enjoy the same ultra-responsive actuation found in our top gaming mice with 4 paddles built into the controller’s ergonomic, rubberized handles—topped with 2 claw grip bumpers for even more control.
Razer Pro HyperTriggers
  • Instant Response with Lightning-Fast Mouse Click Triggers
Set the triggers for instant actuation with zero-travel time or ultra-precise analog control. Be fully immersed in the action and feel every trigger pull with integrated haptic vibrations.
Hall Effect Precision Thumbsticks
  • Anti-Drift Accuracy with Customizable Sensitivity
Experience analog thumbsticks that are not only more accurate than traditional models, but are smoother, lighter and more durable thanks to their anti-friction rings and pro-grade materials.
Razer Mecha-Tactile Action Buttons & 8-Way Floating D-Pad
  • Ultra-Fast Actuations with Tactile Feedback
By combining the speed of microswitches with the cushioned comfort of a rubber membrane, compete with quicker inputs that feel just as comfortable to press.
Pro-Level Customization for Xbox & PC
  • Via the Razer Controller App
Set your thumbstick sensitivity and create custom button layouts using our dedicated app. Store a personalized profile and be ready for any type of competition.
Detachable 10 ft USB Type C Cable
  • Tournament-Ready Convenience
Be ready to compete on Xbox or PC with a portable plug-and-play design. Hook it up and enjoy a zero-latency wired connection crucial for competitive play.
  • Responsive Controls
    The gamepad features A, B, X, Y buttons, thumb sticks, triggers, bumpers, and rear paddles that deliver quick response times, allowing for seamless gameplay.
  • Detachable Cable
    The detachable cable adds convenience for storage or transport, ensuring that the gamepad is easily manageable when not in use.
  • Ergonomic Design
    Designed for comfort during extended gaming sessions, the ergonomic layout of the gamepad helps reduce fatigue and improve control.
  • Plug-and-play Compatibility
    With Plug-and-Play standards, the gamepad requires no complex setup, allowing players to jump into their games without delay.
  • Versatile Platform Compatibility
    Compatible with both PC and Microsoft Xbox Series S and X, the gamepad caters to a wide range of gaming preferences and setups.
Razer Wolverine V3 - Tournament Edition - gamepad - wired
Gamepad
Wired
Controls
A button, B button, D-pad, X button, Y button, 2 thumb sticks, 4 rear paddles, 2 bumpers, 2 triggers
Detachable cable, built-in audio jack
1-year warranty
Microsoft Xbox Series X, Microsoft Xbox Series S, PC
Gamepad
Wired
Controls
USB
Windows 11 or later
15.67 cm
10.57 cm
6.5 cm
Cable Length
3 m
Plug and Play
Limited warranty - 1 year
Compatibility: PC
Compatibility: Microsoft Xbox Series X
Brand: Razer
