Razer Wolverine V3 Pro - Black
Quicklinx: HTJHWS00 Mfr#: RZ06-05200100-R3M1
Wired / Wireless: Wireless, Wired
Compatibility: PC, Microsoft Xbox Series X, Microsoft Xbox Series S
£157.50 ex VAT
£189.00 inc VAT
Stay one step, one shot, and one level above the competition with the Razer Wolverine V3 Pro—the definitive wireless esports controller. Officially licensed by Xbox, play like the world’s best on console and PC with speed, control, and precision that helps you clutch up for the win.
4 Mouse Click Back Paddles & 2 Claw Grip Bumpers
  • 6 Remappable Buttons to Outplay Them All
Enjoy the same ultra-responsive actuation found in our top gaming mice with 4 paddles built into the controller’s ergonomic, rubberized handles—topped with 2 claw grip bumpers for even more control.
Razer Pro HyperTriggers
  • Instant Response with Lightning-Fast Mouse Click Triggers
Set the triggers for instant actuation with zero-travel time or ultra-precise analog control. Be fully immersed in the action and feel every trigger pull with integrated haptic vibrations.
Hall Effect Precision Thumbsticks
  • Anti-Drift Accuracy with Customizable Sensitivity
Experience analog thumbsticks that are not only more accurate than traditional models, but are smoother, lighter and more durable thanks to their anti-friction rings and pro-grade materials.
Razer HyperSpeed Wireless
  • Lag-free, Esports-Grade Performance
Delivering an ultra-low-latency 2.4 GHz connection via its USB Type A dongle, experience fast, reliable performance that meets the demands of the most intense competitive players on Xbox and PC.
Razer Mecha-Tactile Action Buttons & 8-Way Floating D-Pad
  • Ultra-Fast Actuations with Tactile Feedback
By combining the speed of microswitches with the cushioned comfort of a rubber membrane, compete with quicker inputs that feel just as comfortable to press.
Pro-Level Customization for Xbox & PC
  • Via the Razer Controller App
Set your thumbstick sensitivity and create custom button layouts using our dedicated app. Store a personalized profile and be ready for any type of competition.
PC Tournament Mode
  • 1000Hz Polling Rate for Competitive Play on PC
When playing wired on PC, a special Tournament Mode enabling 1000Hz polling rate can be switched on using the companion app or via a controller shortcut.
  • Customizable controls
    The gamepad features an array of controls including A, B, X, Y buttons, two triggers, two bumpers, and four rear paddles that can be programmed for various actions, enabling gamers to create a layout that suits their play style.
  • Dual connectivity options
    With the ability to connect wirelessly or via USB-C, the Razer Wolverine V3 Pro allows players to choose their preferred mode for a more flexible gaming experience, whether at home or on-the-go.
  • Enhanced visual experience
    Featuring Razer Chroma lighting, this gamepad offers a range of customizable lighting effects that enhance the aesthetic and create an immersive atmosphere while gaming.
  • Wide compatibility
    The Razer Wolverine V3 Pro is compatible with Microsoft Xbox Series S, Microsoft Xbox Series X, and PC, ensuring that it can be used across multiple platforms.
  • Extended reach
    With a 3 m cable, the gamepad provides enough length for comfortable gameplay from a distance, allowing gamers to easily settle in without restriction.
Razer Wolverine V3 Pro - gamepad - wireless, wired
Gamepad
Wireless, wired
Controls
A button, B button, D-pad, X button, Y button, 4 rear paddles, 2 bumpers, 2 triggers
1-year warranty
PC, Microsoft Xbox Series S, Microsoft Xbox Series X
Gamepad
Wireless, wired
Controls
USB-C
Carrying case
10.57 cm
15.67 cm
6.5 cm
304 g
Cable Length
3 m
Limited warranty - 1 year
Wired / Wireless: Wired
Compatibility: PC
Compatibility: Microsoft Xbox Series X
Compatibility: Microsoft Xbox Series S
Brand: Razer
