Razer Wolverine V2 Pro (PlayStation Licensed) - White
Quicklinx: HRJJWS00 Mfr#: RZ06-04710200-R3G1
Wired / Wireless: Wired
Hurry, only 2 left in stock!
£157.50 ex VAT
£189.00 inc VAT
Seize the unfair advantage with both hands with the Razer Wolverine V2 Pro - a high-performance wireless controller officially licensed by PlayStation. Armed with Razer HyperSpeed Wireless and a loadout of advanced features for top-tier competitive play, the time has come to claim your rule on PS5 and PC.
  • Razer HyperSpeed Wireless
    Delivering an ultra-fast 2.4 GHz wireless connection via its included USB Type A dongle, the controller ensures seamless performance that meets the demands of competitive gaming on PS5 consoles and PC.
  • Razer Mecha-Tactile Action Buttons
    With a shorter actuation distance for quicker button presses and improved tactility to feel every input, the controller brings a whole new level of speed and consistency to your game. Equipped with a 3-million tap life cycle for greater durability and a reduced actuation distance of 0.65 mm - 35% less than that of the average membrane controller - each button is finely tuned for greater accuracy to showcase your true gaming potential.
  • Razer HyperTrigger
    Always be first to fire with triggers that can switch from measured, full-range pulls to lightning-quick clicks that feel like the actuation in Razer's fastest gaming mice. Toggling the two slide-locks on the controller's underside greatly reduces the travel distance of the main triggers - an advantage that allows you to spam commands at a faster rate.
  • 8-way Microswitch D-Pad
    Feel and hear every single directional press as microswitches are engaged, enabling accurate and intentional moves when doing intricate combos.
  • 6 remappable buttons and interchangeable thumbsticks
    Map its 4 extra triggers and 2 custom bumpers to your preferred commands, and further tailor the controller to your playstyle with 2 additional thumbstick caps.
Razer Wolverine V2 Pro - wired
Wired
Wired
Brand: Razer
