Razer Wolverine V2 Pro (PlayStation Licensed) - Black
Quicklinx: HF4HWS00 Mfr#: RZ06-04710100-R3G1
Type: Game pad
Wired / Wireless: Wired, Wireless
Compatibility: Android, Sony PlayStation 5, iOS, PC
£157.50 ex VAT
£189.00 inc VAT
Seize the unfair advantage with both hands with the Razer Wolverine V2 Pro - a high-performance wireless controller officially licensed by PlayStation. Armed with Razer HyperSpeed Wireless and a loadout of advanced features for top-tier competitive play, the time has come to claim your rule on PS5 and PC.
Razer HyperSpeed Wireless for low-latency, gaming grade performance. Delivering an ultra-fast 2.4GHz wireless connection via its included USB-A dongle, the controller ensures seamless performance that meets the demands of competitive gaming on PS5 consoles and PC. Razer Mecha-Tactile Action Buttons for ultra-fast actuation with tactile feedback. With a shorter actuation distance for quicker button presses and improved tactility to feel every input, the controller brings a whole new level of speed and consistency to your game. 8-Way Microswitch D-Pad for articulate and precise control in fighting games.
Feel and hear every single directional press as microswitches are engaged, enabling accurate and intentional moves when doing intricate combos. Razer HyperTrigger for quickfire execution in FPS games. Always be first to fire with triggers that can switch from measured, full-range pulls to lightning-quick clicks that feel like the actuation in our fastest gaming mice. 6 Remappable Buttons and Interchangeable Thumbsticks for customized layouts and control. Map its 4 extra triggers and 2 custom bumpers to your preferred commands, and further tailor the controller to your playstyle with 2 additional thumbstick caps. Powered by Razer Chroma RGB for greater personalization.
  • "Razer™ HyperSpeed Wireless for low-latency, gaming grade performance"
  • "Razer™ Mecha-Tactile Action Buttons for ultra-fast actuation with tactile feedback"
  • "8-Way Microswitch D-Pad for articulate and precise control in fighting games"
  • "Razer™ HyperTrigger for quickfire execution in FPS games "
  • "6 Remappable Buttons and Interchangeable Thumbsticks for customized layouts and control "
  • "Powered by Razer Chroma™ RGB for greater personalization "
  • Height: 65 MM
  • Width: 106 MM
  • Depth: 162 MM
Manufacturer Warranty - 1 Year
  • Razer HyperSpeed Wireless
    Delivering an ultra-fast 2.4 GHz wireless connection via its included USB Type A dongle, the controller ensures seamless performance that meets the demands of competitive gaming on PS5 consoles and PC.
  • Razer Mecha-Tactile Action Buttons
    With a shorter actuation distance for quicker button presses and improved tactility to feel every input, the controller brings a whole new level of speed and consistency to your game. Equipped with a 3-million tap life cycle for greater durability and a reduced actuation distance of 0.65 mm - 35% less than that of the average membrane controller - each button is finely tuned for greater accuracy to showcase your true gaming potential.
  • Razer HyperTrigger
    Always be first to fire with triggers that can switch from measured, full-range pulls to lightning-quick clicks that feel like the actuation in Razer's fastest gaming mice. Toggling the two slide-locks on the controller's underside greatly reduces the travel distance of the main triggers - an advantage that allows you to spam commands at a faster rate.
  • 8-way Microswitch D-Pad
  • 6 remappable buttons and interchangeable thumbsticks
Razer Wolverine V2 Pro - gamepad - wireless, wired - Bluetooth
Gamepad
Wireless, wired - Bluetooth
Controls
D-pad
6 programmable buttons
PC, Sony PlayStation 5, Android, iOS
Gamepad
Controls
D-pad
16.75 cm
10.58 cm
6.52 cm
279 g
Type: Game pad
Wired / Wireless: Wireless
Compatibility: Sony PlayStation 5
Compatibility: iOS
Compatibility: PC
Brand: Razer
