Razer Wolverine V2 Chroma
Quicklinx: HF4DWS00 Mfr#: RZ06-04010100-R3M1
£83.33 ex VAT
£99.99 inc VAT
With the Razer Wolverine V2 Chroma, get the next-gen customizability. Armed with extra remappable buttons, Razer Chroma RGB, swappable thumbsticks and more, you'll always be spoiled for choice when it comes to tearing up the competition.
  • Razer Mecha-Tactile Action buttons and D-Pad
    Similar tech found in the gaming mice that deliver hyper-responsive actuation with a cushioned touch, Razer Mecha-Tactile Action Buttons and D-Pad empower your every move with cutting-edge precision and crisp tactile feedback for a competitive edge. Equipped with a 3-million tap life cycle for greater durability and a reduced actuation distance of 0.65mm - 35% less than that of the average membrane controller - each button is finely tuned for greater accuracy to showcase your true gaming potential.
  • 6 additional multi-function buttons
    With 4 extra triggers and 2 remappable bumpers via its Razer Controller Setup for Xbox app, the controller provides all the input options you need to increase your arsenal of commands.
  • Interchangeable thumbstick caps
    Choose the right tool for the job and easily swap out included thumbstick caps depending on your playstyle and ergonomic preference. Enjoy more natural and precise analog motion no matter how you use your thumbsticks.
  • Hair trigger mode with trigger stop-switches
    Toggling the two slide-locks on the controller's underside greatly reduces the travel distance of the main triggers - an advantage that allows you to spam commands at a faster rate.
  • Improved ergonomics
    The controller's modified L-shaped handgrips come with non-slip rubber grips for a secure yet agile hold - natural, effortless control for all-day gaming. Ergonomic L-shaped hand grips provide more support for your hands and allow easier access to the bumpers and triggers
  • Advanced app configuration
    Download the Razer Controller Setup for Xbox app to customize the controller to match your playstyle. Easily remap buttons, adjust lighting effects, control motor rumble, and pin-point sensitivity settings.
Razer Wolverine V2 Chroma - gamepad - wired
Gamepad
Wired
Controls
A button, B button, D-pad, X button, Y button, 2 joysticks, LT button, RB button, RT button, LB button
Razer Mecha-Tactile Action Buttons, Razer Mecha-Tactile D-Pad, mapping function, interchangeable thumbsticks, Hair Trigger Mode, built-in audio jack, 6 additional multi-function buttons, built-in microphone jack, Razer Chroma RGB
1-year warranty
Microsoft Xbox Series S, Microsoft Xbox One, PC, Microsoft Xbox Series X
Gamepad
Wired
Controls
USB-C
Windows 10
16.15 cm
10.68 cm
6.5 cm
270 g
Cable Length
3 m
Limited warranty - 1 year
Type: Game pad
Wired / Wireless: Wired
Compatibility: Microsoft Xbox Series S
Compatibility: Microsoft Xbox Series X
Compatibility: Microsoft Xbox One
Compatibility: PC
Brand: Razer
