Razer Viper V3 Pro - White
Quicklinx: HP8VWS00 Mfr#: RZ01-05120200-R3G1
Wired / Wireless: Wireless, Wired
Colour: White
£125.93 ex VAT
£151.11 inc VAT
FOR THE PRO: LIGHTER, FASTER, BETTER
The GOAT of wireless esports mice returns to reshape the competitive scene. Featuring an ultra-lightweight design and best-in-class technologies, the Razer Viper V3 Pro is the undisputed choice for peak performance and handling—the perfect weapon designed with and trusted by pros.
Seamless Handling. Maximum Control.
Designed in collaboration with world-class esports pros, the Viper V3 Pro’s perfectly balanced ultra-lightweight design allows you to make swift, precise flicks that match your every intention.
DYNAMIC SENSITIVITY
Enable deeper control of your DPI output and mouse input to best suit your playstyle.
ROTATION TOOL
Adjust mouse orientation for horizontal swipes.
DPI STEP ADJUSTMENTS
Achieve pixel-perfect sensitivity with single DPI step increments.
SENSITIVITY MATCHER
Precisely port over the DPI settings of your current mouse to the Viper V3 Pro.
SMART TRACKING
Auto-calibrates to maintain a consistent lift-off distance on all surfaces.
  • High-precision tracking
    Equipped with a 35,000 DPI optical sensor, the Razer Viper V3 Pro offers precision and responsiveness, making every movement count in the heat of competition.
  • Versatile connectivity
    With both wired and wireless connectivity options, this mouse ensures a seamless and stable connection, whether you're at a desk or on the go. The inclusion of a USB Type-C to Type-A cable alongside a wireless dongle provides flexibility for any setup.
  • Customizable control
    Featuring 6 programmable buttons, the Razer Viper V3 Pro allows for tailored configurations. This customization extends to grip tape included in the package, ensuring a comfortable and secure hold during extended gaming sessions.
Razer Viper V3 Pro - mouse - USB - white
Mouse
Wired, wireless - USB
White
Orientation
Right-handed
6.39 cm x 12.71 cm x 3.99 cm
55 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
35000 dpi
Performance
750 inches per second, 70 G maximum acceleration, 90 million clicks
Programmable buttons, Focus Pro optical sensor, symmetrical design
Mouse
Orientation
Right-handed
6.39 cm
12.71 cm
3.99 cm
55 g
White
Input Device
Wired, wireless
USB
Optical
Buttons Qty
6
Movement Resolution
35000 dpi
Performance
Grip tape, wireless dongle, USB cable (Type-C to Type-A)
Run Time (Up To)
95 hour(s)
Wired / Wireless: Wired
Colour: White
Brand: Razer
