FOR THE PRO: LIGHTER, FASTER, BETTER
The GOAT of wireless esports mice returns to reshape the competitive scene. Featuring an ultra-lightweight design and best-in-class technologies, the Razer Viper V3 Pro is the undisputed choice for peak performance and handling—the perfect weapon designed with and trusted by pros.
Seamless Handling. Maximum Control.
Designed in collaboration with world-class esports pros, the Viper V3 Pro’s perfectly balanced ultra-lightweight design allows you to make swift, precise flicks that match your every intention.
DYNAMIC SENSITIVITY
Enable deeper control of your DPI output and mouse input to best suit your playstyle.
ROTATION TOOL
Adjust mouse orientation for horizontal swipes.
DPI STEP ADJUSTMENTS
Achieve pixel-perfect sensitivity with single DPI step increments.
SENSITIVITY MATCHER
Precisely port over the DPI settings of your current mouse to the Viper V3 Pro.
SMART TRACKING
Auto-calibrates to maintain a consistent lift-off distance on all surfaces.
High-precision tracking
Equipped with a 35,000 DPI optical sensor, the Razer Viper V3 Pro offers precision and responsiveness, making every movement count in the heat of competition. -
Versatile connectivity
With both wired and wireless connectivity options, this mouse ensures a seamless and stable connection, whether you're at a desk or on the go. The inclusion of a USB Type-C to Type-A cable alongside a wireless dongle provides flexibility for any setup. -
Customizable control
Featuring 6 programmable buttons, the Razer Viper V3 Pro allows for tailored configurations. This customization extends to grip tape included in the package, ensuring a comfortable and secure hold during extended gaming sessions.
- Razer Viper V3 Pro - mouse - USB - white
- Mouse
- Connectivity Technology
- Wired, wireless - USB
- White
- Orientation
- Right-handed
- 6.39 cm x 12.71 cm x 3.99 cm
- 55 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 35000 dpi
- Performance
- 750 inches per second, 70 G maximum acceleration, 90 million clicks
- Programmable buttons, Focus Pro optical sensor, symmetrical design
- Mouse
- Orientation
- Right-handed
- 6.39 cm
- 12.71 cm
- 3.99 cm
- 55 g
- White
Input Device
- Wired, wireless
- Interface
- USB
- Optical
- Buttons Qty
- 6
- 35000 dpi
- Performance
- Included Accessories
- Grip tape, wireless dongle, USB cable (Type-C to Type-A)
- Run Time (Up To)
- 95 hour(s)
