Razer Viper V2 Pro
Quicklinx: GTDPWS00 Mfr#: RZ01-04390100-R3G1
Type: Mouse
£115.84 ex VAT
£139.00 inc VAT
Razer Viper V2 Pro - For the Pro
Esports has a new apex predator. As successor to the award-winning Razer Viper Ultimate, our latest evolution is more than 20% lighter and armed with all-round upgrades for enhanced performance. With one of the lightest wireless gaming mice ever, there’s now nothing holding you back.
Unlock ultra-fine adjustments
Enable Asymmetric Cut-off to individually set a lift-off and landing distance that’s tuned to your playstyle—with 26 granular levels of height adjustment compared to only 3 in the previous version.
Other best in class benefits
Improved surface compatibility
Tracks Flawlessly on Glass
Better Power Efficency
Up to 80 hours of battery life
Power through an insane amount of gaming with a type C rechargeable desgin
Razer Hyperspeed wireless
25% Faster than other wireless tech, featuring multi-device support
On-mouse DPI Control
Capable of toggling between 5 DPI stages without the need for software, you’ll always be ready to compete anywhere with this highly portable, ultra-lightweight esports mouse.
Onboard Memory
The mouse stores and uses its last used Razer Synapse profile, including all calibrated settings such as:
  • DPI
  • Polling rate
  • Lift-off distance
Razer Hypershift
Effectively double your inputs at the touch of a button, as you activate an additional set of custom keybinds and DPI stage on the mouse.
  • Upgradeable to true 4000 Hz wireless polling rate
    Experience a faster wireless performance with the Razer HyperPolling wireless dongle. Unlock a standard of responsiveness with the ultimate upgrade for Razer more advanced mice, to secure the speed you need for top-flight competitive gaming.
  • Razer Focus Pro 30K optical sensor
    Teaming up with Pixart, Razer is proud to present to you a more precise optical sensor. Take a closer look as the break down the upgrades in the breakthrough tech.
  • Unlock ultra-fine adjustments
    Enable asymmetric cut-off to individually set a lift-off and landing distance that's tuned to your playstyle - with 26 granular levels of height adjustment compared to only 3 in the previous version.
  • Auto-calibrates across different surfaces
    With Smart Tracking, the Razer Focus Pro optical sensor is able to maintain a consistent lift-off distance no matter what surface it's used on, allowing for greater control and accuracy.
  • Higher responsiveness and more consistent tracking
    With Motion Sync, the Razer Focus Pro optical sensor syncs its signals to the exact intervals your PC extracts information, ensuring you'll get the most current updates of your mouse position for more consistent tracking.
  • Power to perform
    90-million click lifecycle with no double-clicking issues. Power through an insane amount of gaming with a Type C rechargeable design. 25% faster than other wireless tech, featuring multi-device support.
Razer Viper V2 Pro - mouse - for esports - USB-C - black
Mouse
Wireless, wired - USB-C
Orientation
Right-handed
5.76 cm x 12.67 cm x 3.78 cm
58 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
30000 dpi
Performance
70 G maximum acceleration, 750 inches per second, 90 million clicks
Gaming
Razer Hyperspeed Wireless technology, scrolling wheel, Focus Pro optical sensor, polytetrafluoroethylene (PTFE) feet, 5 DPI levels
Mouse
Wireless Receiver
Orientation
Right-handed
Gaming
5.76 cm
12.67 cm
3.78 cm
58 g
Input Device
Wireless, wired
USB-C
Optical
Buttons Qty
5
Movement Resolution
30000 dpi
Performance
USB cable (Type-C to Type-A), grip tape, USB wireless adapter, USB dongle
Type: Mouse
Brand: Razer
