Razer Universal Xbox Pro Charging Stand Robot White
Quicklinx: GJR2WS00 Mfr#: RC21-01750300-R3M1
Colours:
If you're looking for the fastest way to keep your Xbox controller at prime power levels, then go for the perfect pairing with the Razer universal quick charging stand for Xbox
Quick Charge
Able to fully charge your controller in under 3 hours, the stand is also designed with overcharge protection to prevent overheating and short circuiting
Universal Compatibility
Whether you're on next-gen, last-gen, or staying oldschool, the Razer Universal Quick Charging Stand for Xbox works with all controllers old and new.*
*Excluding Xbox Elite Controller Series 2
Magnetic Contact System
Mount your controller easily and never worry about its charge being interrupted thanks to a magnetic design that secures the controller to the stand.
Matches your Xbox Controller
To perfectly suit your setup, this charging stand uses the same durable material and shares the same striking colors as official Xbox Series X|S controllers.
Power By USB
Simply hook up the charging stand to your Xbox, PC, or compatible wall plugs to get it working.
What’s Inside
  • Razer Universal Quick Charging Stand for Xbox
    • Xbox Series X|S battery cover
    • Rechargeable battery
    • Xbox One battery cover
    • Important Product Information Guide
    • Type C to Type A cable
  • Quick charge
    Able to fully charge your controller in under 3 hours, the stand is also designed with overcharge protection to prevent overheating and short circuiting.
  • Universal compatibility
    Whether you're on next-gen, last-gen, or staying old-school, the Razer universal quick charging stand for Xbox works with all controllers.
Razer charging stand
Charging stand
White
Microsoft Xbox One Wireless Controller, Wireless Controller
1 Year
Charging stand
Wireless game controller
Enclosure Colour
White
Input Connectors
24 pin USB-C
Magnetic fixation
1 Year
