POWERING A LEGACY OF PLAY
Powering a legacy of play, the Razer Universal Quick Charging Stand for Xbox 20th Anniversary Limited Edition is an essential that celebrates 20 years of gaming, passion, and friendships while keeping your controller at prime power levels—because those who play together, stay together
MATCHING XBOX 20TH ANNIVERSARY THEME
To perfectly suit your setup, this charging stand uses the same durable material and shares the same striking colors and design as the Xbox Wireless Controller – Xbox 20th Anniversary Limited Edition
QUICK CHARGE
Able to fully charge your controller in under 3 ?hours, the stand is also designed with overcharge? protection to prevent overheating and short? circuiting.
MAGNETIC CONTACT SYSTEM
Mount your controller easily and never worry? about its charge being interrupted thanks to a? magnetic design that secures the controller to? the stand
POWERED BY USB
Simply hook up the charging stand to your Xbox,? PC, or compatible wall plugs to get it working
What’s Inside
- Razer Universal Quick Charging Stand for Xbox
- Xbox Series X|S battery cover
- Rechargeable battery
- Xbox One battery cover
- Important Product Information Guide
- Type C to Type A cable
Quick charge
Able to fully charge your controller in under 3 hours, the stand is also designed with overcharge protection to prevent overheating and short circuiting. -
Magnetic contact system
Mount your controller easily and never worry about its charge being interrupted thanks to a magnetic design that secures the controller to the stand. -
Powered by USB
Simply hook up the charging stand to your Xbox, PC, or compatible wall plugs to get it working.
- Razer 20th Anniversary Limited Edition charging stand - with battery
- Product Type
- Charging stand + battery
- Cables
- USB-C to USB-A cable
- Designed For
- Microsoft Xbox Wireless Controller (20th Anniversary Special Edition)
- 1 Year
- Product Type
- Charging stand battery
- Designed For
- Wireless game controller
- Input Connectors
- 24 pin USB-C
- Input Connectors Qty
- 1
- Magnetic fixation
- Cables Included
- Designed For
- 1 Year
