If you’re looking for the fastest way to keep your PS5 DualSense wireless controller? at prime power levels, then go for the perfect pairing with the Razer Quick Charging Stand.
Able to fully charge your controller in under 3 hours, the stand is also designed with? overcharge protection to prevent overheating and short circuiting.
Easily mount your controller and never worry about the charging stand falling over thanks? to a design and stable build that perfectly seats the PS5™ DualSense™ wireless controller.
To perfectly suit your setup, this charging stand shares the same striking colors as the galaxy inspired DualSense™ wireless controllers.
Simply hook up the charging stand to your PS5™ console, PC, or compatible wall plugs (sold separately) to get powered up and start charging.
Quick charge
Able to fully charge your controller in under three hours, the stand is also designed with overcharge protection to prevent overheating and short circuiting. -
Curved cradle design
Easily mount your controller and never worry about the charging stand falling over thanks to a design and stable build that perfectly seats the PS5 DualSense wireless controller. -
Matches your PS5 DualSense wireless controller
To perfectly suit your setup, this charging stand shares the same striking colors as the galaxy inspired DualSense wireless controllers. -
Powered by USB
Simply hook up the charging stand to your PS5 console, PC, or compatible wall plugs (sold separately) to get powered up and start charging.
- Razer charging stand
- Product Type
- Charging stand
- Designed For
- Wireless game controller
- 120 mm x 60 mm x 75 mm
- 245 g
- White
- 1-year warranty
- Designed For
- Sony DualSense
- Product Type
- Charging stand
- Designed For
- 120 mm
- 60 mm
- 75 mm
- 245 g
- Enclosure Colour
- White
- Compatible Game Consoles
- Sony PlayStation 5
- Limited warranty - 1 year
- Designed For
- Sony DualSense
