Razer Taipan Expert Ambidextrous Gaming Mouse
Quicklinx: 873SWS00 Mfr#: RZ01-00780100-R3U1
Put fear into the hearts of your foes, as you win with the Razer Taipan
Razer Taipan is an ambidextrous gaming mouse designed to enhance 8200 dpi 4G dual sensor system, get the absolute precision to execute headshots with ease, as well as lightning fast swiping acceleration to hit your foes faster than they can react.
The Razer Taipan has an ambidextrously ergonomic design, a perfected form that molds naturally to its wielder's hand. Countless pro-gamers with a variety of grip and play-styles have validated this mouse as perfect for their needs. Whether they are right-handed or south-paw; use palm, claw, or fingertip grip style - this mouse ensures everyone gets the most comfortable swiping experience and reduced fatigue over extended periods of play. Fight longer as your foes rage-quit in exhaustion.
The Razer Taipan is powered by Razer Synapse 2.0, cutting-edge proprietary software designed to complement Razer's next-generation gaming hardware. It conveniently connects the deadly mouse to a cloud server for automatic syncing of driver and firmware updates. It also stores personal settings like key binds, macros, and DPI profiles, so whether you use a Razer Taipan at home or one provided at an e-Sports tournament, custom settings are downloaded from the cloud so the mouse on-hand is ready for use immediately. And in just the way you like it.
8200 dpi 4G Dual Sensor System
Introducing the all-new 8200dpi 4G Dual Sensor System - outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional pinpoint tracking. This lets you execute headshots with ease while moving with instant in-game responsiveness - a sensor that is a perfect match for your lightning fast reflexes.
Improved ambidextrous ergonomics
Designed with extensive feedback from professional gamers, the Razer Taipan's ambidextrous form suits a wide variety of grip styles and hand sizes. Whether you're right-handed or a south-paw; use claw, palm or fingertip-grip, this mouse stays firmly in hand and comfortably so for extended periods of gaming.
Razer Synapse 2.0 enabled
Razer Synapse 2.0 is cutting-edge, intuitive, proprietary software that functions as the Razer Taipan's brain, automatically syncing the gaming mouse to a cloud server to download driver and firmware updates, as well as to save your individual settings without you needing to lift a finger. You'll never have to set up a new mouse at tournaments again when Razer Synapse 2.0 downloads the personal settings from your own Razer Taipan, and ports them to the new mouse, making it an exact replica of your own
  • 8200 dpi 4G dual sensor system
    The 8200 dpi 4G dual sensor system is outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional pinpoint tracking. This lets you execute headshots with ease while moving with instant in-game responsiveness - a sensor that is a perfect match for your lightning fast reflexes.
  • Improved ambidextrous ergonomics
  • Razer Synapse 2.0 enabled
Razer Expert Ambidextrous Taipan - mouse - USB
Mouse
Wired - USB
6.3 cm x 12.4 cm x 3.6 cm
132 g
Movement Detection Technology
Laser
Buttons Qty
9
Movement Resolution
8200 dpi
Performance
50 G maximum acceleration, 1 ms response time, 200 inches per second
Programmable buttons, Hyperesponse buttons, 4G Dual Sensor System, ambidextrous design
1 x USB cable - integrated
Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.7 or later
Mouse
6.3 cm
12.4 cm
3.6 cm
132 g
Input Device
Wired
USB
Laser
Buttons Qty
9
Movement Resolution
8200 dpi
Performance
1 x USB - 4 pin USB Type A
Software Included
Razer Synapse 2.0
System Requirements Details
HD 100 MB
