Introducing the Razer Strider Chroma - a hybrid mouse mat with multi-lighting zones. Powered by Razer Chroma RGB, enjoy unrivaled levels of personalization with 19 customizable lighting zones, as you experience complete control on an excellent surface.
Hybrid soft/hard mat
Crafted for the optimal balance of speed and control - with a light glide for quick flicks, and solid stopping power for consistent precision. Designed as a single surface for long-lasting durability, unlike coated mats which deteriorate and perform worse over time. -
19 Razer Chroma RGB lighting zones
Be ready to glow with over 16.8 million colors and countless lighting effects, as it dynamically reacts with hundreds of Chroma-integrated games. -
Greater desk coverage
The large mat provides ample space for your keyboard and mouse, while providing maximum RGB illumination for your setup. -
Anti-slip base
The grippy underside is reinforced with a grooved pattern to truly anchor it to your desk. -
Water-resistant
The mat's surface can shrug off any spills, which also allows for easy routine cleaning with a quick wipe down. -
Seamless edges
Unlike most RGB mats with raised stitched edges that impede mouse movement, the Razer Strider Chroma is perfectly level throughout, so it never gets in the way of your game.
- Razer Strider Chroma mouse pad - extended
- Product Type
- Mouse pad
- Size
- Extended
- Product Material
- Polyester
- 37 cm x 90 cm x 4 mm
- 210 g
- 1-year warranty
- Product Type
- Mouse pad
- Size
- Extended
- Product Material
- Polyester
- 37 cm
- 90 cm
- 4 mm
- Thickness
- 4 mm
- 210 g
- RGB lighting effects, Razer Chroma, anti-slip base, water-resistant
- Limited warranty - 1 year
