Gain the winning edge with the Razer Sphex V3 - the latest iteration of the thinnest hard gaming mouse mat, now 20% thinner and available in a larger size.
Smooth, ultra-thin design
Its hard, smoother surface offers fluid, accurate tracking optimized for optical sensors, while its profile is 20% thinner to seamlessly become part of your desk. -
Tough polycarbonate build
Lab-tested to have incredible impact, rip, and tear strength, the Razer Sphex V3 gaming mouse mat is well equipped to handle long hours of intense, competitive gaming. -
Adhesive base
The gaming mouse mat's adhesive base helps it stay anchored to your desk through the most intense sessions but is easy enough to remove without leaving any sticky residue on your setup.
- Razer Sphex V3 Small - mouse pad
- Product Type
- Mouse pad
- Product Material
- Polycarbonate
- 27 cm x 21.5 cm x 0.4 mm
- 9.07 g
- Aesthetic black
- 1-year warranty
- Product Type
- Mouse pad
- Product Material
- Polycarbonate
- 27 cm
- 21.5 cm
- 0.4 mm
- Thickness
- 0.4 mm
- 9.07 g
- Aesthetic black
- Self-adhesive backing
- Limited warranty - 1 year
