Big sounds can come in small packages. Meet the Razer Seiren Mini - an ultra-compact condenser mic that's the perfect fit for professional grade-audio with any streaming or video call setup.
Ultra-precise supercardioid pickup pattern
Because this compact condenser mic is tuned with a tighter pickup angle, it can focus on your voice and has better ambient noise reduction - ensuring that background sounds like typing and mouse clicks are minimized. -
Ultra-compact and portable
Made for minimalist or smaller setups, this compact condenser mic barely takes up any desk space and is discreet on camera so that the focus is always on you. It's also easy to bring along if you need to take your streaming or work elsewhere. -
Heavy-duty tilting stand
The mic is attached to a stable support that can be angled to find the perfect sweetspot for your voice. It can also be detached and mounted on a boom arm or mic stand that uses a standard 5/8-inch thread. -
Built-in shockmount
When accidental knocks and bumps happen, the Razer Seiren Mini's built-in shock mount dampens these vibrations to help protect your stream or colleagues' ears against sound anomalies. -
USB Plug-And-Play
Within seconds of plugging it into a USB port, the Razer Seiren Mini is good to go. Simply set its volume level via the streaming or voice chat software you're using, and let your voice do the rest.
- Razer Seiren Mini - microphone
- Product Type
- Microphone - USB
- Recommended Use
- Computer
- Black
- Microphone Technology
- Condenser
- Microphone Operation Mode
- Super cardioid
- 1 Year
- Product Type
- Microphone - USB
- 8.89 cm
- 8.89 cm
- 16.3 cm
- Black
- Recommended Use
- Computer
Microphone
- Condenser
- Super cardioid
- Connectivity Technology
- Wired
- Sensitivity
- 17.8 mV/Pascal
- Microphone Power Source Voltage (DC)
- 5 V
- Frequency Response
- 20 - 20000 Hz
- Total Harmonic Distortion (THD)
- >1%
- Max Sound Pressure
- 110 dB
- Connector Type
- USB
- Included Accessories
- Desk base stand
- Plug and Play
- 1 Year
