Razer Rogue Backpack (13.3") V3 - Chromatic Edition
Quicklinx: HTJXWS00 Mfr#: RC81-03630116-0000
10 In Stock
£54.77 ex VAT
£65.72 inc VAT
Conquer your commute with the Razer Rogue Backpack V3 – Chromatic Edition, a compact travel companion optimized for toughness and utility. Emblazoned with a holographic wordmark, this special variant of the Rogue ensures you’ll always carry the light, no matter how heavy the fighting gets.
  • Protective interior with spacious compartments
    Its ample interior is lined with TPU - a scratch proof material that guards against abrasion, allowing easy handling - while separate, organized compartments keep your gear safe from impact damage.
  • Dedicated slot for laptops
    Found within the main compartment, the padded laptop slot is lined with soft woven fabric to keep your laptop - tucked away safely and snugly.
  • Zipper pulls and waterproof zipper tape
    New zipper pulls provide easy access to the backpack's front pocket and main compartment - now outfitted with waterproof zipper tapes to keep your gear fully insulated from the elements.
  • Molle webbing
    This unique military design allows you to attach an assortment of compatible pouches and accessories, so you can carry more stuff when the need arises.
  • Chromatic wordmark
    Blaze a trail across the city - or go off the beaten track - with a bold, light-reactive holographic wordmark that leaves no doubt as to whose side you're on.
Razer Rogue V3 - notebook carrying backpack
Notebook carrying backpack
Chromatic
Product Material
Polyester, thermoplastic polyurethane (TPU)
26 cm x 14.3 cm x 41 cm
Notebook Compatibility
13.3"
Scratch-proof, water resistant, tear-resistant, weatherproof
Carrying Strap
Hand grip, shoulder carrying straps
Product Material
26 cm
14.3 cm
41 cm
13.3"
Additional Compartments
Front pocket
Carrying Strap
Closure Type
Zipper
Compartments Quantity
2
Chromatic
Brand: Razer
