Razer Orochi V2
Razer Orochi V2
Quicklinx: HNL5WS00 Mfr#: RZ01-03730100-R3G1
Recommended Use: Gaming
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Game console, Mac, PC
£54.16 ex VAT
£64.99 inc VAT
Introducing the Razer Orochi V2 - a compact, ultra-lightweight wireless gaming mouse with an extremely long battery life. Armed with both Razer Hyperspeed Wireless and Bluetooth modes, it's your perfect companion for gaming on the go.
  • Lightweight
    Enjoy faster swipes and deft control with this ultra-lightweight mouse.
  • Universal design
    The Razer Orochi V2's form has been improved upon - purposefully redesigned for a more natural fit that ensures better handling with most grip styles.
  • Portable performance
    The Razer Orochi V2's compact size fits easily into your backpack, ready to be called upon no matter where or when.
  • 2 Wireless modes
    Built for the gaming and work grind, this ultra-lightweight wireless gaming mouse can go for ages before its batteries need replacing.
  • Works with AA or AAA batteries
    Requiring only one AA or AAA battery to work, the Razer Orochi V2 features a hybrid battery slot that's been optimally positioned for balanced weight distribution.
  • Razer 5G advanced optical sensor
    Enjoy responsive, pixel-precise aim with an improved sensor that flawlessly tracks your movement with zero spinouts.
  • 2nd-gen Razer mechanical mouse switches
    With gold-plated contact points, the switches are more resistant to degrading and have a longer lifespan of up to 60 million clicks.
  • 100% PTFE mouse feet
    This portable wireless gaming mouse glides smoothly across any surface with mouse feet made from pure, high grade of PTFE.
  • On-board memory profile
    Be ready to compete anywhere with access to your custom key binds, DPI, and twice the inputs via the Razer HyperShift function.
Razer Orochi V2 - mouse - 2.4 GHz, Bluetooth - black
Mouse
Wireless - 2.4 GHz, Bluetooth
Orientation
Right-handed
6 cm x 10.8 cm x 3.8 cm
60 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
18000 dpi
Performance
450 inches per second, 40 G maximum acceleration, 60 million clicks
Razer 5G optical sensor, Razer 2nd-gen optical mouse switch, Razer Hyperspeed Wireless technology, 6 programmable buttons
AA type
Mouse
Orientation
Right-handed
6 cm
10.8 cm
3.8 cm
60 g
Product Material
PTFE
Input Device
Wireless
2.4 GHz, Bluetooth
Optical
Buttons Qty
6
Movement Resolution
18000 dpi
Performance
1 AA battery
AA type
Lithium
Run Time (Up To)
950 hours
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Razer
