Razer Ornata V3 X - UK Layout
Quicklinx: HF5HWS00 Mfr#: RZ03-04470300-R3W1
Type: Keyboard
More than 50 In Stock
£28.09 ex VAT
£33.70 inc VAT
Take the first step towards next-level performance with the Razer Ornata V3 X - a low-profile ergonomic gaming keyboard designed to elevate your work and play. Featuring an ultra-slim form factor, more durable keycaps, and Razer Chroma RGB, it is the perfect introduction to unfair advantage.
  • Ergonomic gaming experience
    With slimmer keycaps and shorter switches, enjoy natural hand positioning with a low-profile ergonomic gaming keyboard that allows for long hours of use with little strain.
  • Soft, cushioned keystrokes
    The Razer Ornata V3 X is perfect for those who prefer a quieter, more comfortable experience when gaming or typing.
  • Improved fade and scratch resistance
    More durable than regular keycaps, the UV coating ensures more fade resistance and greater protection against wear and tear from frequent use.
  • Durable design
    The Razer Ornata V3 X's sturdy build is tanky enough for those intense gaming sessions and can shrug off the effects of minor spills.
  • Extended gaming support
    Aligns perfectly to the low-profile keyboard and provides the perfect place to rest your wrists - for support that's vital during long periods of use.
  • Customizable lighting
    With 16.8 million colors and a suite of RGB effects to choose from, personalize the keyboard and get access to dynamic lighting effects for hundreds of Chroma-integrated games.
Razer Ornata V3 X - keyboard - QWERTY - UK Input Device
Keyboard
Backlit
RGB Chroma
USB
Wired
Localization and Layout
QWERTY UK
Hot Keys Function
Programmable, macros buttons
Protection
Spill-resistant, UV treated
Numeric Keypad
Gaming
Keyboard
Backlit
RGB Chroma
USB
Hot Keys Function
QWERTY UK
Keyboard Technology
Membrane
Gaming
Adjustable Height
Palm Rest
Protection
Numeric keypad
Included Software
Razer Synapse
Type: Keyboard
Brand: Razer
