Take the first step towards next-level performance with the Razer Ornata V3 X - a low-profile ergonomic gaming keyboard designed to elevate your work and play. Featuring an ultra-slim form factor, more durable keycaps, and Razer Chroma RGB, it is the perfect introduction to unfair advantage.
Ergonomic gaming experience
With slimmer keycaps and shorter switches, enjoy natural hand positioning with a low-profile ergonomic gaming keyboard that allows for long hours of use with little strain. -
Soft, cushioned keystrokes
The Razer Ornata V3 X is perfect for those who prefer a quieter, more comfortable experience when gaming or typing. -
Improved fade and scratch resistance
More durable than regular keycaps, the UV coating ensures more fade resistance and greater protection against wear and tear from frequent use. -
Durable design
The Razer Ornata V3 X's sturdy build is tanky enough for those intense gaming sessions and can shrug off the effects of minor spills. -
Extended gaming support
Aligns perfectly to the low-profile keyboard and provides the perfect place to rest your wrists - for support that's vital during long periods of use. -
Customizable lighting
With 16.8 million colors and a suite of RGB effects to choose from, personalize the keyboard and get access to dynamic lighting effects for hundreds of Chroma-integrated games.
- Razer Ornata V3 X - keyboard - QWERTY - UK Input Device
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Programmable, macros buttons
- Protection
- Spill-resistant, UV treated
- Numeric Keypad
- Gaming
- 2-year warranty
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Membrane
- Gaming
- Adjustable Height
- Palm Rest
- Protection
- Numeric keypad
- Included Software
- Razer Synapse
- Limited warranty - 2 years
