Razer Ornata V3 - UK Layout
Quicklinx: GYB1WS00 Mfr#: RZ03-04460300-R3W1
Marketing description is not available.
  • Ergonomic gaming experience
    With slimmer keycaps and shorter switches, enjoy natural hand positioning with a low-profile ergonomic gaming keyboard that allows for long hours of use with little strain.
  • Clicky keystrokes with a soft, cushioned touch
    Fusing the snappy, clicky feedback of a mechanical switch with the familiar feel of a conventional keyboard, each keystroke you make is as satisfying as it is precise.
  • Improved fade and scratch resistance
    More durable than regular keycaps, the UV coating ensures more fade-resistant legends and greater protection against wear and tear from frequent use.
  • Convenient control
    Configure them to pause, play, skip and adjust everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
  • Extended gaming support
    Designed to seamlessly snap to the low-profile keyboard, the soft-touch wrist rest provides ample comfort and support for your wrists - especially vital for long periods of use.
  • Customizable lighting
    With 16.8 million colors and a suite of RGB effects to choose from, personalize the keyboard and get access to dynamic lighting effects for hundreds of Chroma-integrated games.
Razer Ornata V3 - keyboard - low profile - QWERTY - UK Input Device
Keyboard
Backlit
10 zone RGB
USB
Wired
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, programmable, macros buttons
Protection
Spill-resistant
Numeric Keypad
Gaming
Keyboard
Backlit
10 zone RGB
USB
Input Device
Low profile
Hot Keys Function
QWERTY UK
Keyboard Technology
Mecha-membrane
Gaming
Adjustable Height
Palm Rest
Protection
Spill-resistant
Numeric keypad
Included Software
Razer Synapse
