Razer Nommo V2
Razer Nommo V2
Quicklinx: HRJFWS00 Mfr#: RZ05-04750100-R3G1
£199.17 ex VAT
£239.00 inc VAT
Set the soundstage for victory with the Razer Nommo V2 - a full-range gaming speaker system and subwoofer designed for high-fidelity, room-filling sound and riveting bass. Powered by THX Spatial Audio and Razer Chroma RGB, prepare for an immersive experience that spans across sight and sound.
  • Natural, crystal-clear acoustics
    Enjoy accurate sound reproduction and optimal clarity with a pair of powerful 3" full-range drivers - both fitted with aluminum phase plugs to minimize sound reflections within each speaker.
  • A wide, true-to-life soundstage
    The advanced virtual 7.1 surround sound delivers audio with exceptional accuracy, allowing for a more realistic and detailed soundstage that makes your movies, games, and music come alive.
  • Greater immersion and customization
    Amplify the ambience of your battlestation with rear projection lighting zones on both speakers. Choose from countless patterns and enhance your immersion with dynamic in-game lighting effects.
  • Down-firing subwoofer with 5.5" driver
    Armed with a powerful 5.5" driver that delivers deep, rich lows, enhance the enjoyment of your entertainment with room-thumping bass you can hear and feel.
Razer Nommo V2 - speaker system - for PC - wireless
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Frequency Response
40 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker System Details
2 x speaker , 1 x subwoofer
Sound Effects
7.1 virtual surround sound
7.4 kg
1-year warranty
THX Spatial Audio, THX game profiles, 10-band EQ, Razer Wireless Control Pod Ready
Light
Razer Chroma RGB lights
Speaker System
System Components
Speaker Type
Active
Frequency Response
40 - 20000 Hz
Max Output Level (Max SPL)
98 dB
THX certified
Amplifier
Integrated
Sound Effects
Bluetooth 5.3
Interface Type
USB
Speakers Included
2 x speaker , 1 x subwoofer - wired
Driver Details
Speaker: full-range driver - 3" - aluminium phase plugs , Subwoofer: subwoofer driver - 5.5" - down-firing dome
Connector Type
USB
Power adapter
Power Source
DC power adapter
7.4 kg
Dimensions (WxDxH) / Weight Details
Speaker: 13 cm x 18.1 cm x 18.4 cm / 2.6 kg , Subwoofer: 26.5 cm x 26.5 cm x 30.05 cm / 4.8 kg
Limited warranty - 1 year
System Type: PC multimedia speaker system
Type: 2 speakers
Type: Subwoofer
Power: 69watt
Brand: Razer
