Experience absolute power and precision that blows you away with the Razer Nommo V2 Pro - a fully-loaded, full-range PC speaker system and wireless subwoofer combo. Amplified by THX Spatial Audio and Razer Chroma RGB, set the stage for a cinematic audio-visual experience primed for your battlestation.
3" full-range drivers with aluminum phase plugs
Enjoy accurate sound reproduction and optimal clarity with a pair of powerful 3" full-range drivers - both fitted with aluminum phase plugs to minimize sound reflections within each speaker. -
THX spatial audio
The advanced virtual 7.1 surround sound delivers audio with exceptional accuracy, allowing for a more realistic and detailed soundstage that makes your movies, games, and music come alive. -
THX game profiles
Take your audio experience to the next level with THX game profiles. Apply custom-tuned profiles that enhance the existing sound design in your favorite games for truly realistic acoustics that reflect your surroundings and pinpoint positional audio for better directional hearing. -
Wireless down-firing subwoofer
The system's subwoofer is armed with a 5.5" driver that delivers rich, powerful bass for room-thumping lows, while its wireless design ensures a clean, seamless setup that minimizes on cables. -
Rear projection razer chroma RGB
Amplify the ambience of your battlestation with rear projection lighting zones on both speakers. Choose from countless patterns and enhance your immersion with dynamic in-game lighting effects. -
Razer wireless control pod
Controlling the Razer Nommo V2 Pro is made even easier when paired with the included Razer wireless control pod. Adjust settings such as volume, audio EQ, and more with greater ease and convenience.
- Razer Nommo V2 Pro - speaker system - for PC - wireless
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Frequency Response
- 40 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 2 x speaker , 1 x subwoofer
- Sound Effects
- 7.1 virtual surround sound
- 13 cm x 18.1 cm x 18.4 cm
- 2.65 kg
- 1-year warranty
- Product Type
- THX Spatial Audio, THX game profiles, 10-band EQ, Razer Wireless Control Pod Ready
- Light
- Razer Chroma RGB lights
Speaker System
- System Components
- Speaker Type
- Active
- 40 - 20000 Hz
- Max Output Level (Max SPL)
- 99 dB
- THX certified
- Amplifier
- Integrated
- Sound Effects
- Bluetooth 5.3
- Interface Type
- USB
- Speakers Included
- 2 x speaker , 1 x subwoofer - wireless
- Driver Details
- Speaker: full-range driver - 3" - aluminium phase plugs , Subwoofer: subwoofer driver - 5.5" - down-firing dome
- Connector Type
- USB
- Power Source
- Integrated power supply
- 13 cm
- 18.1 cm
- 18.4 cm
- 2.65 kg
- Dimensions (WxDxH) / Weight Details
- Speaker: 13 cm x 18.1 cm x 18.4 cm , Subwoofer: 26.5 cm x 26.5 cm x 30.05 cm / 4.6 kg
- Limited warranty - 1 year
Razer Nommo V2 Pro
