Razer Nommo V2 Pro
Razer Nommo V2 Pro
Quicklinx: HRJGWS00 Mfr#: RZ05-04740100-R3G1
£290.84 ex VAT
£349.00 inc VAT
Experience absolute power and precision that blows you away with the Razer Nommo V2 Pro - a fully-loaded, full-range PC speaker system and wireless subwoofer combo. Amplified by THX Spatial Audio and Razer Chroma RGB, set the stage for a cinematic audio-visual experience primed for your battlestation.
  • 3" full-range drivers with aluminum phase plugs
    Enjoy accurate sound reproduction and optimal clarity with a pair of powerful 3" full-range drivers - both fitted with aluminum phase plugs to minimize sound reflections within each speaker.
  • THX spatial audio
    The advanced virtual 7.1 surround sound delivers audio with exceptional accuracy, allowing for a more realistic and detailed soundstage that makes your movies, games, and music come alive.
  • THX game profiles
    Take your audio experience to the next level with THX game profiles. Apply custom-tuned profiles that enhance the existing sound design in your favorite games for truly realistic acoustics that reflect your surroundings and pinpoint positional audio for better directional hearing.
  • Wireless down-firing subwoofer
    The system's subwoofer is armed with a 5.5" driver that delivers rich, powerful bass for room-thumping lows, while its wireless design ensures a clean, seamless setup that minimizes on cables.
  • Rear projection razer chroma RGB
    Amplify the ambience of your battlestation with rear projection lighting zones on both speakers. Choose from countless patterns and enhance your immersion with dynamic in-game lighting effects.
  • Razer wireless control pod
    Controlling the Razer Nommo V2 Pro is made even easier when paired with the included Razer wireless control pod. Adjust settings such as volume, audio EQ, and more with greater ease and convenience.
Razer Nommo V2 Pro - speaker system - for PC - wireless
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Frequency Response
40 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker System Details
2 x speaker , 1 x subwoofer
Sound Effects
7.1 virtual surround sound
13 cm x 18.1 cm x 18.4 cm
2.65 kg
1-year warranty
THX Spatial Audio, THX game profiles, 10-band EQ, Razer Wireless Control Pod Ready
Light
Razer Chroma RGB lights
Speaker System
System Components
Speaker Type
Active
Frequency Response
40 - 20000 Hz
Max Output Level (Max SPL)
99 dB
THX certified
Amplifier
Integrated
Sound Effects
Bluetooth 5.3
Interface Type
USB
Speakers Included
2 x speaker , 1 x subwoofer - wireless
Driver Details
Speaker: full-range driver - 3" - aluminium phase plugs , Subwoofer: subwoofer driver - 5.5" - down-firing dome
Connector Type
USB
Power Source
Integrated power supply
13 cm
18.1 cm
18.4 cm
2.65 kg
Dimensions (WxDxH) / Weight Details
Speaker: 13 cm x 18.1 cm x 18.4 cm , Subwoofer: 26.5 cm x 26.5 cm x 30.05 cm / 4.6 kg
Limited warranty - 1 year
System Type: PC multimedia speaker system
Type: 2 speakers
Type: Subwoofer
Power: 200watt
Power: 200watt
Power: 200watt
Power: 200watt
Power: 200watt
Brand: Razer
