Razer Naga V2 Pro
Razer Naga V2 Pro
Quicklinx: HLNKWS00 Mfr#: RZ01-04400100-R3G1
Recommended Use: Office, Gaming
Type: Mouse
Wired / Wireless: Wireless, Wired
Colour: Black
Compatibility: Android, Mac, PC, Game console
£149.99 ex VAT
£179.98 inc VAT
ADAPT AND UNLEASH
Designed to dominate in MMO, Battle Royale, FPS, and more, the multi-genre master returns stronger than ever. With 3 swappable side plates, 19+1 programmable buttons, a Razer HyperScroll Pro Wheel, and Razer HyperSpeed Wireless, the Razer Naga V2 Pro packs the power to rise above every genre.
ABSOLUTE ADAPTABILITY AND CONTROL
3 Swappable Side Plates for Up To 22 Programmable Controls
The Razer Naga V2 Pro comes with a set of 12, 6 and 2-button magnetic side plates, allowing you adapt to any game genre with up to 22 programmable controls.
RAZER™ HYPERSCROLL PRO WHEEL
Unlimited Configuration and Scroll Feel
Toggle between 5 presets and 1 custom mode all at the tap of a button.
FULLY CUSTOMIZABLE SCROLL FEEL
With adjustable tactility, resistance, and steps, create firmer, more distinct scrolls for precise weapon switching, or softer, smoother scrolls with multiple steps to easily spam inputs like jump.
From a scale of 0 to 100, adjust the strength required for each tick of the scroll wheel. The lower the number, the easier it is to scroll—with 0 providing a completely smooth scroll feel. From a scale of 0 to 100, adjust the strength required for each tick of the scroll wheel. The lower the number, the easier it is to scroll—with 0 providing a completely smooth scroll feel.
3 MODES OF CONNECTIVITY
Lasts up to 150 hours on HyperSpeed, 300 hours on Bluetooth, and can be connected via USB Type C for continued use while charging.
RAZER™ FOCUS PRO 30K OPTICAL SENSOR
Razer’s industry leading sensor provides flawless tracking performance on a wider variety of surfaces including glass—supported by intelligent functions for enhanced aim and control.
RAZER™ OPTICAL MOUSE SWITCHES GEN-3 From an improved 90-million click lifecycle with zero double-clicking issues, to a blistering 0.2ms actuation with no debounce delay, enjoy reliability and speed that outshines all others.
  • Absolute adaptability and control
  • Fully customizable scroll feel
  • High-performance, low-latency gaming
    Enjoy ultra-responsive gaming with a connection faster than other wireless tech. Streamline your setup and free up a USB port by connecting your wireless mouse and keyboard to a single dongle - a feature that can be activated in Razer HyperSpeed peripherals.
  • 3 modes of connectivity
  • 30K optical sensor
    Razer's sensor provides flawless tracking performance on a wider variety of surfaces including glass - supported by intelligent functions for enhanced aim and control.
Razer Naga V2 Pro - mouse - MMO, HyperScroll Pro wheel, gaming - Bluetooth, USB-C, 2.4 GHz
Mouse - ergonomic
Wired, wireless - Bluetooth, USB-C, 2.4 GHz
Orientation
Right-handed
7.55 cm x 11.95 cm x 4.35 cm
134 g
Movement Detection Technology
Optical
Buttons Qty
20
Movement Resolution
30000 dpi
Performance
70 G maximum acceleration, 750 inches per second
Gaming
Razer Chroma RGB, Razer Hyperspeed Wireless technology, Razer Speedflex Cable, PTFE mouse feet, Razer HyperScroll technology, on-board memory profile, Focus Pro optical sensor, Razer 3rd-gen optical mouse switch, wireless charging, Razer Synapse 3 enabled, 3 swappable side plates, 90 million clicks, 5 profiles, tiltable scroll wheel
Mouse
Ergonomic Design
Orientation
Right-handed
Gaming
7.55 cm
11.95 cm
4.35 cm
134 g
Input Device
Wired, wireless
Optical
Buttons Qty
20
Movement Resolution
30000 dpi
Performance
2011/65/EU, Directive 2014/30/EU, Directive 2014/53/EU, REACH 2006/1907, EN 301 489-1 V2.2.3, EN 50663:2017, EN 55032:2015+A1:2020, EN 62479:2010, EN55035:2017+A11:2020, ETSI EN 301 489-1 V2.2.1 (2019-03), IEC 62368-1
Run Time (Up To)
300 hour(s)
Software Included
Razer Synapse 3
Recommended Use: Gaming
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac
Compatibility: PC
Compatibility: Game console
Brand: Razer
