The Razer Leviathan easily fits under any desktop monitor or living room console setup. Versatile enough to be repositioned constantly in any situation, this sound bar features cutting-edge Dolby technology, superior sound drivers, and a dedicated subwoofer, projecting rich sounds that recreate epic in-game battle scenes or just streaming your favorite tunes from your smartphone.
Immersive 5.1 channel surround sound for gaming and movies
Enjoy a rich, full-range 5.1 true-to-life surround sound experience with the Razer Leviathan, powered by the award winning Dolby Virtual Speakers. No matter your source type (stereo or multi-channel audio via optical input), Dolby Digital will convert audio from your sound card, console or set-top -
Bluetooth v4.0 aptX for wireless music streaming
The Razer Leviathan seamlessly connects to your Bluetooth devices via Bluetooth v4.0 with the award winning aptX technology for audio quality indistinguishable from a wired connection with an impressive dynamic range. With a connecting range of up to 10 meters, you can enjoy your music without the hassle of wires. The Razer Leviathan also remembers your recently paired devices, allowing you to quickly connect with a single tap. The built in NFC technology allows for ultra-fast pairing. -
Dedicated subwoofer for deep immersive bass
With a powerful 5.25" downward firing subwoofer dedicated specifically for the accurate reproduction of bass, and tuned to produce distortion-free lower frequencies, the Razer Leviathan is made to deliver chest-thumping, deep impact bass. Synergizing with 2 perfectly tuned full ranged drivers and 2 tweeters in the sound bar, the Razer Leviathan lets you experience the entire spectrum of sound by providing crystal clear mids and impressive highs.
- Razer Leviathan V2 Pro - sound bar system - for PC - wireless
- Product Type
- Sound bar system - for PC
- THX Spatial Audio
- Light
- Multicolour LED light
Speaker System
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 150 Watt
- Frequency Response
- 45 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Controls
- Power on/off, volume, equaliser, audio mode, sources switch
- App-Controlled
- Interface Type
- USB
Speaker System Details
- Speakers Included
- 1 x sound bar , 1 x subwoofer
- Speaker Details
- Sound bar - stereo - active , Speaker - subwoofer - active
- Driver Details
- Sound bar: 5 x full-range driver - 2"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 5.25" - down-firing cone
- Connector Type
- USB (USB Type-C) , Headset (mini-phone 3.5mm)
- Power Source
- AC power adapter
- 7.35 kg
- Dimensions (WxDxH) / Weight Details
- Sound bar: 60 cm x 9.01 cm x 11.37 cm / 2.27 kg , Subwoofer: 26 cm x 26 cm x 29.5 cm / 5.08 kg
- Limited warranty - 1 year
