Razer Leviathan V2 Pro
Quicklinx: HTK3WS00 Mfr#: RZ05-04160100-R3G1
Type: Sound bar, Subwoofer
Power: 150watt
£365.84 ex VAT
£439.00 inc VAT
The Razer Leviathan easily fits under any desktop monitor or living room console setup. Versatile enough to be repositioned constantly in any situation, this sound bar features cutting-edge Dolby technology, superior sound drivers, and a dedicated subwoofer, projecting rich sounds that recreate epic in-game battle scenes or just streaming your favorite tunes from your smartphone.
  • Immersive 5.1 channel surround sound for gaming and movies
    Enjoy a rich, full-range 5.1 true-to-life surround sound experience with the Razer Leviathan, powered by the award winning Dolby Virtual Speakers. No matter your source type (stereo or multi-channel audio via optical input), Dolby Digital will convert audio from your sound card, console or set-top
  • Bluetooth v4.0 aptX for wireless music streaming
    The Razer Leviathan seamlessly connects to your Bluetooth devices via Bluetooth v4.0 with the award winning aptX technology for audio quality indistinguishable from a wired connection with an impressive dynamic range. With a connecting range of up to 10 meters, you can enjoy your music without the hassle of wires. The Razer Leviathan also remembers your recently paired devices, allowing you to quickly connect with a single tap. The built in NFC technology allows for ultra-fast pairing.
  • Dedicated subwoofer for deep immersive bass
    With a powerful 5.25" downward firing subwoofer dedicated specifically for the accurate reproduction of bass, and tuned to produce distortion-free lower frequencies, the Razer Leviathan is made to deliver chest-thumping, deep impact bass. Synergizing with 2 perfectly tuned full ranged drivers and 2 tweeters in the sound bar, the Razer Leviathan lets you experience the entire spectrum of sound by providing crystal clear mids and impressive highs.
Razer Leviathan V2 Pro - sound bar system - for PC - wireless
Sound bar system - for PC
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
150 watt
Frequency Response
45 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker System Details
1 x sound bar , 1 x subwoofer
Speaker Details
Sound bar - stereo - active , Speaker - subwoofer - active
7.35 kg
1-year warranty
THX Spatial Audio
Light
Multicolour LED light
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
150 watt
Frequency Response
45 - 20000 Hz
Amplifier
Integrated
Bluetooth
Controls
Equaliser, audio mode, power on/off, volume, sources switch
App-Controlled
Interface Type
USB
Speakers Included
Speaker Details
Driver Details
Sound bar: 5 x full-range driver - 2"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 5.25" - down-firing cone
Connector Type
USB (USB Type-C) , Headset (mini-phone 3.5mm)
Power Source
AC power adapter
7.35 kg
Dimensions (WxDxH) / Weight Details
Sound bar: 60 cm x 9.01 cm x 11.37 cm / 2.27 kg , Subwoofer: 26 cm x 26 cm x 29.5 cm / 5.08 kg
Limited warranty - 1 year
Type: Sound bar
Type: Subwoofer
Power: 150watt
Brand: Razer
