Razer Leviathan V2
Razer Leviathan V2
Quicklinx: HRJDWS00 Mfr#: RZ05-03920100-R3G1
System Type: Sound bar for PC
Type: Sound bar, Subwoofer
Power: 65Watt
Hurry, only 1 left in stock!
£165.84 ex VAT
£199.00 inc VAT
Amp up your setup in every way imaginable with the Razer Leviathan V2 - a multi-driver gaming soundbar and subwoofer featuring THX spatial audio and Razer Chroma RGB. Experience unrivaled immersion in both sight and sound, backed by low-latency Bluetooth 5.2 for seamless PC and mobile use.
  • Crisp, clear trebles and deep, punchy bass
    Packed with 2 full-range drivers, a down-firing subwoofer, and more, the all-in-one sound system is designed to provide full-range, high-fidelity sound that elevates your audio experience.
  • A wide, true-to-life soundstage
    The advanced 7.1 surround sound delivers audio with pinpoint accuracy, allowing for a more realistic and detailed soundstage that makes your movies, games, and music truly come alive.
  • Room-filling sound and minimal footprint
    The compact soundbar fits perfectly beneath your monitor to keep your desktop clutter-free, while detachable rubber feet keep it angled towards you for minimal audio obstruction.
  • Seamless PC and mobile connection
    Enjoy smooth, stutter-free sound with a low-latency Bluetooth connection, as you switch from your PC to another paired device such as a smartphone or tablet.
  • Greater customization and immersion
    With 18 lighting zones, countless patterns, dynamic in-game lighting effects - experience full RGB customization and deeper immersion with the world's largest lighting ecosystem for gaming devices.
Razer Leviathan V2 - sound bar system - for PC - wireless
Sound bar system - for PC
System Components
Subwoofer, sound bar
Speaker Type
Active
Audio System Peak Power (Total)
65 Watt
Frequency Response
45 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker System Details
1 x sound bar , 1 x subwoofer
Speaker Details
Sound bar - stereo x 2 - active , Speaker - subwoofer - active
1-year warranty
Light
Multicolour LED light
Speaker System
System Components
Speaker Type
Active
65 Watt
Frequency Response
45 - 20000 Hz
Amplifier
Integrated
Bluetooth 5.2
Controls
Power on/off, volume
App-Controlled
Interface Type
USB
Speakers Included
1 x sound bar - 2-way , 1 x subwoofer - wired
Speaker Details
Driver Details
Sound bar: 2 x full-range driver - 2" x 4" , Sound bar: 2 x tweeter driver - 0.75" , Sound bar: 2 x Passive Radiator - 1.7" x 5.3"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 5.5" - down-firing cone
Connector Type
USB (USB Type-C)
AC power adaptor
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Sound bar: 50 cm x 24.15 cm x 22 cm / 1.4 kg , Subwoofer: 22 cm x 24.15 cm x 22 cm / 3 kg
1-year warranty
Type: Sound bar
Type: Subwoofer
Power: 65Watt
Brand: Razer
