The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end.
The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go.
The Razer Kraken is outfitted with large 40mm neodymium magnet drivers tuned for crystal clear music in the high-and mid-ranges and packing deep bass for powerful lows, making them versatile music and gaming headphones.
Designed for maximum comfort and durability
The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end. -
Foldable ear cups for maximum portability
The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go. -
Large 40mm Neodymium drivers for powerful audio
- Razer Kraken X Lite - headset - 3.5 mm jack
- Product Type
- Headset - 7.1 channel - wired - 3.5 mm jack
- Compatibility
- Mac, Windows
- Recommended Use
- Game console, portable electronics, computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Sound Effects
- 7.1 Channel Virtual Surround Sound
- Audio Specifications
- Frequency Response 12 - 28000 Hz - Sensitivity 109 dB
- Impedance
- 32 ohm
- Noise Isolating
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Cardioid (uni-directional)
- Controls
- Mute, volume control
- 2-year warranty
- Product Type
- Compatibility
- Mac, Windows
- 16 cm
- 8.8 cm
- 21 cm
- 230 g
- Earpad Material
- Leatherette, memory foam
- Recommended Use
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Noise Isolating
- 12 - 28000 Hz
- Sensitivity
- 109 dB
- Impedance
- 32 ohm
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium magnet
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -45 dB
- 100 - 10000 Hz
- Signal-To-Noise Ratio
- 60 dB
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm)
Cable
- Cable Length
- 1.3 m
- Cable Details
- Headset extension cable - 2 m , Headset cable - 1.3 m
- Limited warranty - 2 years
