Razer Kraken X Lite
Razer Kraken X Lite
Quicklinx: HNKYWS00 Mfr#: RZ04-02950100-R381
Type: Headset
24 In Stock
£24.99 ex VAT
£29.98 inc VAT
The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end.
The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go.
The Razer Kraken is outfitted with large 40mm neodymium magnet drivers tuned for crystal clear music in the high-and mid-ranges and packing deep bass for powerful lows, making them versatile music and gaming headphones.
  • Designed for maximum comfort and durability
  • Foldable ear cups for maximum portability
  • Large 40mm Neodymium drivers for powerful audio
Razer Kraken X Lite - headset
Headset - 7.1 channel - wired - 3.5 mm jack
Compatibility
Mac, Windows
Recommended Use
Game console, portable electronics, computer
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 12 - 28000 Hz - Sensitivity 109 dB
Impedance
32 Ohm
Noise Isolating
Microphone
Boom
Microphone Technology
Electret condenser
Microphone Operation Mode
Cardioid (uni-directional)
Controls
Mute, volume control
Compatibility
Mac, Windows
16 cm
8.8 cm
21 cm
230 g
Earpad Material
Leatherette, memory foam
Recommended Use
Audio Output
Full size
Headphones Cup Type
Closed
Dynamic
Wired
Sound Output Mode
Stereo
Sound Effects
Noise Isolating
Frequency Response
12 - 28000 Hz
Sensitivity
109 dB
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium magnet
Microphone
Boom
Headset microphone
Electret condenser
Sensitivity
-45 dB
Frequency Response
100 - 10000 Hz
Signal-To-Noise Ratio
60 dB
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm)
Cable
Cable Length
1.3 m
Cable Details
Headset extension cable - 2 m , Headset cable - 1.3 m
Type: Headset
Brand: Razer
