The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end.
The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go.
The Razer Kraken is outfitted with large 40mm neodymium magnet drivers tuned for crystal clear music in the high-and mid-ranges and packing deep bass for powerful lows, making them versatile music and gaming headphones.
The deepest immersion, unleashed
To reach the ultimate depths of immersion, one must dive beyond sight and sound. Unlock a third sense for gaming with the Razer Kraken V3 Pro - a wireless haptic PC gaming headset powered by Razer HyperSense. With the ability to feel what you hear, gaming has never felt this intense or real -
Feedback that feels real - Razer HyperSense
Cutting-edge haptic drivers in each earcup pick up on audio cues and convert them into realistic vibrations that vary in position, duration, and intensity, providing touch-sensory feedback for in-game sounds -
Stereo haptics
Haptic effects flow between left and right earcups based on in-game positioning for greater spatial awareness and immersion -
Real-time haptics
Intelligent audio processing that requires zero integration or additional downloads to work. Compatible across games, music, and movies -
Intensity adjuster
Easily adjust the haptics' strength with an on-headset button that can toggle between off, low, medium, and high -
Immersion from every angle - thx spatial audio
The headset is armed with advanced 7.1 surround sound that optimizes your game's sound design for realistic positional audio. Experience true-to-life acoustics and hear everything as if you were right in the middle of it all -
Powerful, lifelike audio - Razer TriForce titanium 50mm drivers
Our patented 3-part driver design pushes out exceptional highs, mids, and lows that doesn't muddy, providing a more dynamic listening experience for deeper immersion. Upgraded with titanium-coated diaphragms for superior clarity, the drivers enable truly lifelike and accurate sound reproduction -
Sound that's seamless Razer hyper-speed wireless
The haptic headset's industry-leading 2.4GHz wireless connection ensures lossless, low-latency audio that syncs perfectly with game visuals, so you'll never experience a break in immersion -
Hybrid fabric and leatherette memory foam cushions
The perfect balance of comfort, sound isolation, and haptics transfer. -
Razer HyperClear super-cardioid mic
The larger 9.9mm detachable mic suppresses more noise from the back and sides and provides a truer recreation of your voice thanks to a sensitive low frequency response -
Works with PlayStation - wirelessly
The Razer Kraken V3 Pro comes with a wireless dongle that's compatible with PlayStation so you can plug and play instantly, allowing you to enhance your overall console immersion through the combined haptics of your headset and controller -
Powered by Razer Chroma RGB
With 16.8 million colors and a suite of effects, enjoy greater immersion as it dynamically reacts with over 150 integrated games. Hold down the Razer HyperSense adjuster button to conveniently cycle through Razer Chroma RGB lighting effects
- Razer Kraken V3 Pro - headset
- Product Type
- Headset - 2.4 GHz - wireless, wired - 3.5 mm jack
- Recommended Use
- Game console, computer
- Additional Functions
- RGB lighting
- Style
- Games
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- 2.4 GHz radio frequency
- Sound Output Mode
- Stereo
- Sound Effects
- THX Spatial Audio
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional (HyperClear super cardioid)
- Controls
- Mute, volume, Haptics intensity
- 2-year warranty
- Product Type
- RGB lighting
- Style
- Games
- 368 g
- Earpad Material
- Leatherette, memory foam
- Recommended Use
Audio Output
- Full size
- Wireless, wired
- Sound Output Mode
- Stereo
- Sound Effects
- THX Spatial Audio
- 20 - 20000 Hz
- Sensitivity
- 96 dB
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Razer Triforce titanium
- Adjustable Headband
- Razer HyperSense, Razer Chroma RGB
Microphone
- Boom
- Sensitivity
- -42 dB
- Sensitivity Margin
- +/- 3dB
- 100 - 10000 Hz
- Signal-To-Noise Ratio
- 60 dB
Remote Control
- Controls
- Connector Type
- Headset (mini-phone 3.5 mm 4-pole)
- Included Accessories
- USB dongle
- Cable Details
- USB-C to USB-A cable - detachable , Mini-phone 3.5 mm 4-pole cable - detachable - 1.3 m
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 44 hour(s)
- Run Time Details
- (lighting OFF / Haptics OFF): up to 44 hours , (lighting ON / Haptics ON): up to 11 hours
- Limited warranty - 2 years
